Dear list,
I am managing a bulk cleaning of pseudo-network data, where nodes
"more o less" overlap links, but never break links itself (usually
links have no vertex near those nodes)
I am using v.distance between pseudo-nodes and links, followed by
parsing db.select output and then piping it to v.edit, tool=break
when trying to update links length, I realized something was wrong
because of identical CATs of links just edited
rebuilding theme was useless, because this way I lost attributes on
new elements, while I need to inherit all of them, except for length
same problem adding new cat on a different layer (this way I get a
unique cat field, but I lost all attributes )
to update my length field I do really need a UNIQUE_value CAT, but I
found no other way to get a UNIQUE value CAT than brutally exporting
theme in shp and reloading it using v.in.ogr
this post [1] suggest a similar issue on v.split
reading this paper [2] about v.edit, break and split seem different
tools (different record management?)
on the other hand, grass manuals of v.edit (6.4, 7.0) tell "break:
Break/split vector lines" like synonyms
is there a better/smarter way to solve this problem?
perhaps (but really complex):
1. parsing ids from v.edit where cat = old cat,
2. get last category in use
3. modify one item setting cat = last category +1,
4. insert new record on attribute table copying data where cat = old
category and setting cat = last category +1
5. re-connect data
or I am missing something about grass vector editing and categories management?
thank you
Enrico
[1] http://www.mail-archive.com/grass-user@lists.osgeo.org/msg01509.html
[2] http://gislab.dirap.unipa.it/grass_meeting/articoli/grass-digit.pdf
