Hi list,
I observed a strange thing about v.external. When I crate a link to a shapefile using v.external, it is possible to list all attribute values using the v.db.select-command (on the command line).
However, I was not successful in trying to get the same result inside of QGIS or directly inside the database-backend (I am using sqlite-/sqlitebrowser).
1) sqlitebrowser does not even list the table of the theme created with v.external
2) in QGIS (0.8.0 R2), I can load some (only line and polygon) layers into the map (the geometry is shown), but I do not have access to the attributes - only cat-values are shown.
Therefore, it would be helpful to know, whether this is a bug or not. Any ideas? More than welcome.
Best regards,
Wolfgang
"Feel free" - 5 GB Mailbox, 50 FreeSMS/Monat ...
Jetzt GMX ProMail testen: http://www.gmx.net/de/go/promail?ac=OM.GX.GX003K11711T4781a
On 05/02/07 14:19, Wolfgang Qual wrote:
Hi list, I observed a strange thing about v.external. When I crate a
with v.external
v.external does not import any data, it just links to it, so any attribute data is in the .dbf file linked to your shapefile, and not in your sqlite database.
I guess QGIS can only work with "real" GRASS data, i.e. data imported into GRASS, and not data which you only link to with v.external.
Moritz
