John_R
1
Hello,
I am running GRASS 6.3.0 on Linux. I would like to use a postgis table as a read only vector layer in GRASS.
One time I had v.external doing more than it does now. Here is a typical execution:
# v.external 'dsn=PG:host=localhost user=postgres dbname=spatial_db' output=gpxpints_pg
Data source contains 1 layers:
trackpnt
This would be the behavior I would expect if "output" was not defined. There is no vector layer created in GRASS.
What is the next debugging step here?
John
On Tue, Feb 24, 2009 at 2:05 AM, John R. <johnr@wowway.com> wrote:
Hello,
execution:
output=gpxpints_pg
trackpnt
You need to define
layer=trackpnt
as well.
John_R
3
Markus Neteler wrote:
You need to define
layer=trackpnt
as well.
Thanks...that was it.
I had not mentally made the association between layer and table.
John
