[GRASS-user] v.extract and layer/table settings with layer=2
this is maybe I quite easy routine for somebody that is using v.extract regularly.
Here my challenge: I have a vector map (initially created by v.net tools) that has several layers and associated tables to each layer. Now for further processing I want to extract only some features from layer=2 and the corresponding attribute table.
I can do that using “v.extract input=mymap1 layer=2 where=‘mycol=x’ output=mymap2”. The resulting ‘mymap2’ has an attribute table connected to layer 2 and there are no other layers (e.g. there is no layer 1, which is considered in most grass tools as default layer). So I wanted to change that and to shift layer 2 (and the attribute table) to layer 1 using “v.category option=chlayer layer=‘2,1’ input=mymap2 output=mymap3”
…however, this does not change the attribute table connection (as checked by "v.db.connect -p "). So I guess I also have to use v.db.connect in some way (??) to get the attribute table shifted from connection at former layer 2 to layer 1 (unused).
In my opinion this is quite a bit complicated, considering that I just wanted to extract some features from a 3-layered map?? Is there a easier way or a general description if one want to extract some feature that are not stored in layer 1?
All the best,
Johannes
Am 27. November 2018 20:51:37 MEZ schrieb Johannes Radinger <johannesradinger@gmail.com>:
regularly.
tools)
and
I can do that using "v.extract input=mymap1 layer=2 where='mycol=x'
output=mymap2". The resulting 'mymap2' has an attribute table connected
to
is
"v.category option=chlayer layer='2,1' input=mymap2 output=mymap3"
...however, this does not change the attribute table connection (as
checked
some
layer
Yes:
v.db.connect -d layer=2
v.db.connect layer=1 table=
easier
are
The best would probably be some form of output_layer parameter in v.extract, probably with a default of 1. Worth a trac ticket I think.
Moritz
Thank you Moritz for clarification…
…I also issued an enhancement ticket for v.extract to include a new output_layer parameter (https://trac.osgeo.org/grass/ticket/3700#ticket)
/J
On Wed, Nov 28, 2018 at 8:26 AM Moritz Lennert <mlennert@club.worldonline.be> wrote:
regularly.
tools)
and
to
is
checked
some
layer
Yes:
easier
are
Moritz
