Roy
1
Dear all,
i'm trying to extract some vectors using attribute names using python script: (grass 6.4.4)
i have a column with "des" values : river, canal
and i have to extract only the features of type 'canal'
then of type 'river' and so on...
import grass.script as grass
env = grass.gisenv()
grass.run_command('v.extract', input='idro', output='canal_idro', where='des = canal', overwrite='True')
maybe i'm missing the correct sintiax of the "where" clause because i only get
a buffer overflow as result,
thanks for any help,
Roy.
neteler
2
On Sat, Feb 14, 2015 at 4:00 PM, Roy <royroge@outlook.com> wrote:
Dear all,
get a buffer overflow as result,
You need to quote the text string "canal", i.e. where='des = "canal"'
Here a NC dataset example
grass.run_command('v.extract', input='roadsmajor', output='nc55',
where='ROAD_NAME = "NC-55"', overwrite='True')
HTH,
Roy
3
Dear Markus,
it works using sqlite as database provider both in GRASS 6.4.4 and GRASS 7.0.0 R.C.2,
i was not aware that GRASS overrides the sqlite limitation "cannot drop column", really a nice feature to have,
thank you very much,
Roy.
HTH,
