Hello,
after some month a tried an script again which
calls v.generalize. It seems that this module
has changed in version 6.4.2 and 6.5SVN.
Before I could use following:
grass.run_command("v.generalize",
input = input,
output = "vector_gen",
method = "boyle",
look_ahead = 8,
overwrite = True)
Now it seems that v.generalize needs a threshold value (required!)
although the manual states only: Input parameters: input, look_ahead
I am confused now if this value is really necessary for calculating boyle's algorithm and if yes how should a value be choosen?
Moreover I'd like to know what means the 'r' flag (backwards compatibility), were there any major changes in recent time (last year)?
Best regards,
Johannes
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://www.gmx.net/de/go/freephone/
Johannes Radinger wrote:
Hello,
input = input,
method = "boyle",
look_ahead = 8,
overwrite = True)
Right, the module requires threshold, but Boyle (and some other
methods) do not require threshold, instead they require other
parameters. Threshold being required is maybe annoying, but not that
serious, more serious is that the module does not check if all
parameters for the selected method are specified.
Threshold is not used by boyle, just give the module some dummy value.
A number of bugs were fixed because v.generalize produced corrupt
output in 6.4.1 (see e.g. recent ml thread [1]).
Markus M
[1] http://lists.osgeo.org/pipermail/grass-user/2012-January/063327.html
Hi Markus,
-------- Original-Nachricht --------
Datum: Tue, 7 Feb 2012 18:00:26 +0100
Von: Markus Metz <markus.metz.giswork@googlemail.com>
An: Johannes Radinger <JRadinger@gmx.at>
CC: grASS user list <grass-user@lists.osgeo.org>
Betreff: Re: [GRASS-user] v.generalize threshold and boyle\'s algorithm
> Hello,
> input = input,
> method = "boyle",
> look_ahead = 8,
> overwrite = True)
Thank you for that answer. Of course its not of big deal to provide a dummy value, I was just confused.
/johannes
Markus M
