[GRASS-user] v.hull ignoring 'where' argument
I have set of points with attribute table (let just say with column “A” containing 1s and 2s).
I would love to use function v.hull in order to get two convex hulls (their faces). Basically apply function “by group”. Unfortunatelly, I was not able to find simple way to do that.
First solution I came up with was scripting with for cycle using “category” - picking ids of points and then run:
v.hull input=mypoints output=myhulls1 cat=“1,3,40,etc”
v.hull input=mypoints output=myhulls2 cat=“2,4,41,etc”
Than I tried where clause:
v.hull input=mypoints output=myhulls1 where=“A<2”
v.hull input=mypoints output=myhulls2 where=“A>1”
Unfortunatelly, this clumsy solution (I have hounderds thousands of point sets) does not work. All four lines gave me the same result (convex hull created from all points).
The only even more clumsy solution I succeded with was first use ‘v.extract’ and than apply ‘v.hull’ on newly created maps.
My questions:
Is there a way how to effectively apply function(command) by group?
Is the v.hull function supposed to work like this (ingnoring where and cat arguments)?
Thank you
Vil
Vilem Ded wrote
I have set of points with attribute table (let just say with column "A"
(their
faces). Basically apply function "by group". Unfortunatelly, I was not
able
"category"
v.hull input=mypoints output=myhulls1 cat="1,3,40,etc"
v.hull input=mypoints output=myhulls2 cat="2,4,41,etc"
v.hull input=mypoints output=myhulls1 where="A<2"
v.hull input=mypoints output=myhulls2 where="A>1"
'v.extract'
and than apply 'v.hull' on newly created maps.
My questions:
arguments)?
confirmed that where or cat seems not to work. please open a ticket for
this.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
On Thu, Feb 22, 2018 at 10:05 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
Vilem Ded wrote
(their
able
“category”
  • picking ids of points and then run:
‘v.extract’
My questions:
arguments)?
this.
From the manual:
layer=string
Layer number or name (‘-1’ for all layers)
Default: -1
You need to set the layer option to some positive number, otherwise all points from all layers will be used and the cats and where options are ignored.
HTH,
Markus M
best regards
Helmut
grass-user mailing list
grass-user@lists.osgeo.org
On Thu, Feb 22, 2018 at 12:39 PM, Markus Metz
Vilem Ded wrote
> My questions:
> cat arguments)?
From the manual:
layer=string
    Layer number or name ('-1' for all layers)
    Default: -1
ignored.
I have added a related note to the v.hull manual page (maybe others
should be extended as well?).
markusN
2018-02-22 21:02 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
probably. The module could print a warning instead of silent ignoring options.
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Thu, Feb 22, 2018 at 9:10 PM, Martin Landa <landa.martin@gmail.com> wrote:
+1
applies to other modules as well where the default layer is -1 and cats and where options are available
Markus M
Ma
Martin Landa
