The 8.0.dev manual for v.in.ascii describes the column identifiers:
x=integer
Number of column used as x coordinate (points mode)
First column is 1
Default: 1
y=integer
Number of column used as y coordinate (points mode)
First column is 1
Default: 2
z=integer
Number of column used as z coordinate (points mode)
First column is 1. If 0, z coordinate is not used
Default: 0
Entering v.in.ascii on the command line (lines wrapped in alpine):
v.in.ascii -z
in=~/projects/washington/project/data/bathymetry/coe/CL_33_LDYX_20210712_CS.xyz
out=lady_xsec_depths for=point x=1 y=2 z=3 col='x double precision, y double
precision, z integer' --o
yields this response from GRASS:
WARNING: ntokens: 1, xcol: 0, ycol: 1, zcol: 2
ERROR: Broken row 2: '7709581.42,697951.64,24'
When I change the command to match the above:
ERROR: Column numbers must not be negative
GRASS project/bathymetry:analyses > ERROR: Column numbers must not be negative
And when I try it again:
bash: GRASS: command not found
What might be going on here? Now neither the command line nor the GUI will
import an ASCII point file.
Rich
Hi Rich,
Please check your "separator" settings. Default is pipe |, but your data seems to be comma delimited.
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces@lists.osgeo.org> On Behalf Of Rich Shepard
Sent: fredag 1. oktober 2021 18:07
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] v.in.ascii column identifications
x=integer
First column is 1
Default: 1
y=integer
First column is 1
Default: 2
z=integer
Default: 0
v.in.ascii -z
out=lady_xsec_depths for=point x=1 y=2 z=3 col='x double precision, y double precision, z integer' --o
ERROR: Column numbers must not be negative GRASS project/bathymetry:analyses > ERROR: Column numbers must not be negative
What might be going on here? Now neither the command line nor the GUI will import an ASCII point file.
Rich
grass-user mailing list
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgrass-user&data=04|01|Stefan.Blumentrath%40nina.no|febb7f0f75b04a758b1008d984f57cf7|6cef373021314901831055b3abf02c73|0|0|637687012593647527|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|3000&sdata=wPke%2FDQRpWHE0Xg6jZwhrh0XoVEOkj9ISz51fH6fXQg%3D&reserved=0
Stefan,
In the GUI I selected 'comma', forgot to do so on the command line.
Regardless, the GUI didn't bring in the data. I'll check it again.
Rich
