Hi everybody
I’m still on GRASS 6.0.1 and I want to create a vector point file by v.in.ascii (point mode). It works good (a point vector is created )but this command doesn’t create a dbf table associated with this vector (I’m a on dbf driver). Is this a bug of the 6.0.1 version or is there a manipulation that i forgot ?
I a also try the standard mode of v.in.ascii and it doesn’t work too
Mick
2006/12/1, Michaël Rabotin <michaelrabotin@gmail.com>:
Hi everybody
I'm still on GRASS 6.0.1 and I want to create a vector point file by
command doesn't create a dbf table associated with this vector (I'm a on dbf
i forgot ?
I a also try the standard mode of v.in.ascii and it doesn't work too
Mick
for me it works (creating vector map & attribute table) -- tested in 6.2/6.3
Best regards, Martin
grassuser mailing list
grassuser@grass.itc.it
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
It works for me with v.in.ascii, but no table is created when I used v.hull, v.delaunay and v.patch. Is that right?
PPCMac G5 and the latest William's cvs.
Agustin
On Dec 1, 2006, at 7:18 PM, Martin Landa wrote:
Hi everybody
i forgot ?
Mickfor me it works (creating vector map & attribute table) -- tested in 6.2/6.3
http://grass.itc.it/mailman/listinfo/grassuser--
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *_______________________________________________
