[GRASS-user] v.in.ascii error: G_realloc
thanks Markus for your help. v.in.ascii is working fine now.
But now I have problems with the created vector file. I think because of the
missing topology.
If I want to use the created vector file for example with v.patch I get the
error:
Cannot open old vector dtm1107_32@Solothurn on level 2
The same error if I use g.region vect=dtm1107_32
Another example: If I use v.surf.rst I get the error:
Vector is not 3D
Any suggestions how I can solve the problem?
Thanks
Michael
Hi Michael,
GRASS 6.1 can (probably) deal with such a number of points, but
you have to add the '-b' flag to not build the topology. See
http://grass.itc.it/grass61/manuals/html61_user/v.in.ascii.html
On Fri, Aug 04, 2006 at 08:55:24AM +0100, Praktikant/in2 ARP wrote:
Hi everybody
I wanted to import a large ASCII File in Grass 6.0.2 (about 300MB and
about
11.000.000 Points).
First everything was going fine but after some time i got the mistake:
ERROR: G_realloc: out of memory
What's going wrong?
Is it not possible to import such large files in Grass or is there a
maximum
size untill which v.in.ascii is working fine?
Thanks for your help
Michael
grassuser mailing list
grassuser@grass.itc.it
On Fri, Aug 04, 2006 at 12:30:45PM +0100, Praktikant/in2 ARP wrote:
missing topology.
error:
Only a couple of commands work without topology (to allow
working with large number of points). Would be good if
someone documents that in the Wiki.
Vector is not 3D
Maybe you forgot the -z setting in v.in.ascii to import as 3D?
