[GRASS-user] v.in.ascii : ERROR: write sidx
Hello,
I have just installed GRASS 7.0 svn 57844 on Linux Mint 15.
v.in.ascii stopped during the build process : “ERROR: write sidx: wrong node position in file”
Like this :
Scanning input for column types…
Number of columns: 3
Importing points…
100%
Building topology for vector map PTS_menhir2_pc_88M@menhir2
Registering primitives…
88509169 primitives registered
88509169 vertices registered
Building areas…
100%
0 areas built
0 isles built
Attaching islands…
Attaching centroids…
100%
Number of nodes: 0
Number of primitives: 88509169
Number of points: 88509169
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
The command was :
v.in.ascii -z input=${FILE} output=${NAME_OUT} separator=“${FS}” z=3 --overwrite
From a shell script.
Is this a known issue ?
yann
Le Jeune Yann wrote:
Hello,
v.in.ascii stopped during the build process : "ERROR: write sidx: wrong node
position in file"
Like this :
Scanning input for column types...
Importing points...
100%
Building topology for vector map <PTS_menhir2_pc_88M@menhir2>...
Registering primitives...
Building areas...
100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
100%
Number of nodes: 0
Number of lines: 0
Number of areas: 0
Number of isles: 0
If you are using a 32bit OS, you might need large file support (LFS)
which is by default enabled. LFS can but should not be disabled with
--disable-largefile.
Do you have enough free disk space?
If you do not need topology for the points, you can try v.in.ascii -b.
The command was :
v.in.ascii -z input=${FILE} output=${NAME_OUT} separator="${FS}" z=3
--overwrite
No.
Markus M
i use a 64 bit system, with LFS
Yes
that works for me, Thanks a lot !!
yann
Sorry, in Fact i still need topology for further processes,
Any ideas ?
Thanks
yann
2013/9/26 Le Jeune Yann <lj.yann@gmail.com>
Yann Le Jeune
Web : http://www.paleosystem.fr/ylj_pro/
–disable-largefile.
Yes
yann
Any ideas ?
May be now you are able to build the topology using "v.build" module,
or do you have still a error?
Pietro
I tried v.build after v.in.ascii -b and there’s the same error at the same step… :frowning:
2013/9/26 Pietro <peter.zamb@gmail.com>
Any ideas ?
May be now you are able to build the topology using “v.build” module,
Pietro
Yann Le Jeune
Yann wrote:
The command was :
v.in.ascii -z input=${FILE} output=${NAME_OUT} separator="${FS}" z=3 --overwrite
just to note -- the {curly} brackets do nothing to
protect from spaces in filenames in this situation,
"double" quotes should be used for that.
the curly brackets protect the variable name, not its
contents, so are mostly useful for when a letter,
number, or "_" follows the variable name.
I actually think it is dangerous to use the curly
brackets because it tricks people into thinking they
are protected when they are not.
regards,
Hamish
Thanks for the {curly} thing !
I tried v.in.ascii from the Layer manager (i use sqlite driver) :
(Thu Sep 26 23:58:29 2013)
v.in.ascii -z --overwrite --verbose input=/media/yann/DATA_SIG/3D_photo/menhir2_pc_88M.csv output=PTS_menhir2_pc_88M separator= z=3
WARNING: Vector map <PTS_menhir2_pc_88M> already exists and will be overwritten
Using native format
Maximum input row length: 30
Importing points…
Building areas…
0 areas built
0 isles built
Attaching islands…
Topology was built
Number of nodes: 0
Number of lines: 0
Number of areas: 0
Number of isles: 0
(Fri Sep 27 00:44:28 2013) Command finished (45 min 59 sec)
I have some disk space, but i looked at my system monitor and my RAM went to SWAP (i have only 16 Go RAM, 15 Go SWAP) The swap don’t seems to have been totally used (but at least half) and i have not in front of my PC when the error occurred.
I will try this again with more RAM.
Thanks for your answers.
yann
2013/9/26 Hamish <hamish_b@yahoo.com>
Yann wrote:
The command was :
just to note – the {curly} brackets do nothing to
“double” quotes should be used for that.
number, or “_” follows the variable name.
regards,
Hamish
v.in.ascii
Using native format
Importing points...
Building areas...
0 areas built
0 isles built
Topology was built
Number of nodes: 0
Number of lines: 0
Number of areas: 0
Number of isles: 0
went to SWAP (i have only 16 Go RAM, 15 Go SWAP) The swap don't seems
Ok, 88 million points and running 64bit Linux. Since 3D points
and no additional data columns columns I think it will default
to not creating a database, so you don't have to worry about the
-t flag or the memory needed for that, just the finite amount of
RAM per point for topology. Maybe 64GB RAM will be enough for 88M,
perhaps more, but it will need a lot to build topology for all those
points.
May I ask what process you'd like to do with the data? Perhaps
r.in.xyz + r.to.vect helps reduce the number of points to something
more manageable. The v.in.ascii '-r' flag can be helpful for importing
only those points within the current computational region of interest,
and if importing without building topology (the '-b' flag you tried
before) many of the LiDAR modules and v.surf.rst have been modified
to work without needing it.
If it is some other vector module maybe we can modify it to load data
without topology too.
Is it sparse x,y data or gridded?
regards,
Hamish
SWAP (i have only 16 Go RAM, 15 Go SWAP) The swap don't seems to have been
error occurred.
You can try to set the environment variable GRASS_VECTOR_LOWMEM with
export GRASS_VECTOR_LOWMEM=1
This will substantially reduce memory requirements when building
topology, particularly for points. You will need a bit of free disk
space where your grassdata are located.
HTH,
Markus M
yann
Yann wrote:
> The command was :
> --overwrite
regards,
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
points.
Ok
I am processing point clouds from photogrammetry (here an engraved
megalith, 6.5 m²) and LIDAR data in forested areas (archaeology at another
scale).
For this i am working on a script that perform all classical processes (for
achaeologist, including qualimetry, animations, PDF maps etc.) for all
*.csv file in a given directory. It's a work in progress, shellscript, but
i hope to do this in C and/ or in a contribution to grass if it worth it.
Perhaps
more manageable.
I will try this.
ok, i will looke at that too.
i use also v.neighbors
It's sparse data.
Thanks à lot !!!
yann
2013/9/27 Markus Metz <markus.metz.giswork@gmail.com>
Ok, thanks !
i will try this too.
yann
I tried r.in.xyz and it’s perfect for me.
Thanks a lot !
yann
2013/9/27 Le Jeune Yann <lj.yann@gmail.com>
Yann Le Jeune
Ok, thanks !
yann
Yann wrote:
> The command was :
> --overwrite
Hamish wrote:
Maybe "${FILE}" then? I remember this as being Glynn's recommendation, some
time ago...
Best, Nikos
On Thu, Oct 3, 2013 at 8:44 PM, Nikos Alexandris <nik@nikosalexandris.net> wrote:
Yann wrote:
The command was :
–overwrite
Hamish wrote:
Maybe “${FILE}” then? I remember this as being Glynn’s recommendation, some
time ago…
Yes “${FILE}” should protect spaces and variable name.
$ MY_VARIABLE=“GRASS is GIS”
$ for A in $MY_VARIABLE; do echo $A; done;
is
GIS
$ for A in “${MY_VARIABLE}”; do echo $A; done;
GRASS is GIS
But if I want to make thinks robust I use Python. Although module call itself is more complicated
input=file_name
is less complicated than
input=“${FILE}”
Best,
Vaclav
Best, Nikos
