[GRASS-user] v.in.ascii howto
How should one import an ASCII file which begins with:
---<---------------cut here---------------start-------------->---
ORGANIZATION:
DIGIT DATE:
DIGIT NAME:
MAP NAME:
MAP DATE:
MAP SCALE: 1
OTHER INFO:
ZONE: 0
WEST EDGE: -360.000000
EAST EDGE: 360.000000
SOUTH EDGE: -90.000000
NORTH EDGE: 90.000000
MAP THRESH: 0.0001
VERTI:
L 1435084 2
XXX.XXXXXX XX.XXXXXX
---<---------------cut here---------------end---------------->---
Essentially example 1a in the man page for v.in.ascii, which
unfortunately doesn't have a command to show how this should be
imported. Any advice would be appreciated. Thanks.
Seb
Never mind, I was misunderstanding that the "standard mode" in the man
page is actually the standard format, so passing format=standard is
what's needed in this case.
On Fri, 07 Nov 2008 22:30:37 -0600,
"Sebastian P. Luque" <spluque@gmail.com> wrote:
Hi, How should one import an ASCII file which begins with:
ORGANIZATION: DIGIT DATE: DIGIT NAME: MAP NAME: MAP DATE:
MAP SCALE: 1 OTHER INFO: ZONE: 0 WEST EDGE:
-360.000000 EAST EDGE: 360.000000 SOUTH EDGE: -90.000000 NORTH
EDGE: 90.000000 MAP THRESH: 0.0001 VERTI: L 1435084 2 XXX.XXXXXX
XX.XXXXXX .......... .........
Seb
Good point. I have changed the docs:
standard mode -> standard format mode
On Sat, 8 Nov 2008 09:54:16 +0100,
man page is actually the standard format,
The page also warns "Note the blank before entering vertex
coordinates". Is this strictly necessary? Thanks.
Seb
What version of Grass are you using? I can't this message in
the html help in either 6.4 or 7.0svn.
Regardless, I've updated the examples to show the full command-line
import call. I can import vectors in standard format with or without spaces
on each coordinate line; I'll put a note in the docs saying it isn't
necessary to pad with spaces.
(Aside: does anyone know why spaces were placed on each coordinate line
in v.in.ascii example 1a? Cosmetics?)
~ Eric.
On Wed, 12 Nov 2008 11:06:14 -0500,
What version of Grass are you using? I can't this message in the html
This is in the Debian sid release 6.2.3-2.1.
spaces on each coordinate line; I'll put a note in the docs saying it
isn't necessary to pad with spaces.
line in v.in.ascii example 1a? Cosmetics?)
Thanks!! These issues certainly confused me so I wasn't sure what the
standard format really is.
Seb
Seb:
Not anymore, but having that extra space helps for clarity and is what
v.out.ascii writes.
Eric:
(so the help page has already had that statement removed)
Eric:
IMO spaces should be encouraged, but not mandatory.
> I'll put a note in the docs saying it isn't necessary to pad with
> spaces.
I would just say nothing at all about it. At most something along the lines
of excess whitespace will be ignored, but then we have to guarantee that.
I would think it would be better to spend the effort to highlight the -n
flag for standard mode without header (ex. 1b).
IIRC it was a requirement in GRASS 5 which was removed for GRASS 6 (much
more importantly y,x was changed to x,y then).
Hamish
Hamish:
Eric:
> spaces.
Hamish:
Done. I've highlighted the function of -z and -n in Ex.1b, and applied a number of other
cleanups, to 6.4 and 7.0 as r34274 and r34273, respectively.
~ Eric.
