Dear List,
I have a tab-delimited text (.txt) file and I am experimenting with importing points into GRASS (6.5 svn) in Snow Leopard.
Here is the content of the file:
675166.97 4450516.81 246 Orhan
675135.87 4450516.98 250 Osman
675156.68 4450501.48 250 Sehitlik
675155.74 4450560.93 243 SaatKulesi
675192.48 4450504.39 245 Kuledenilerisi
The first two columns are UTM (zone 36) east and north readings, the third is the elevation and the last column is the explanation for each point.
In ‘v.in.ascii’ module, I specified point as the format and typed tab (I also tried \t). I left x and y column numbers at default (1 for x, 2 for y), I did not specify z or column definition.
Here is the error message i am getting:
Scanning input for column types…
Maximum input row length: 9
Maximum number of columns: 1
Minimum number of columns: 1
ERROR: y column number > minimum last column number
(incorrect field separator?)
- I tried importing this file without decimals at the end of each coordinate, and used ’ | ’ instead of tab as delimiter. The result is the same. What am I doing wrong?
BÜLENT
