I have been using v.in.ascii for some time and performance has been very good through GRASS 6.3.0. However, with GRASS 6.4.0 importing ascii points is painfully slow. What is causing this; can I speed-up the process with any options? The -b option (Don't build topology points does not seem to help.
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
Thank you for your response. The columns are: longitude|latitude|value. With
previous versions of GRASS, the import process might be ~30 seconds, at
most. Now, 10 -to- 15 minutes. This is radar based precipitation estimates
for 1-hr over the Ohio R valley in the U.S.
seems to be OK here (6.4.svn)
$ time v.in.ascii in=xmrg0106200804z.ascii out=test --q
real 0m19.592s
user 0m12.269s
sys 0m3.116s
$ v.info test -t | grep points
points=65000
Martin
Thomas E Adams
help.
help.
how many points in the file? (wc -l filename.txt)
what database backend?
Hamish
Thomas E Adams
I believe I know what the problem is (to a degree). I am running GRASS in a network environment where GRASS is installed on one machine, my user files are on a 2nd, my GRASS database is on a 3rd, and I am logged into a 4th (all on Redhat Linux). So, reading my file over the -network- must be causing the big slowdown. One week ago we installed a new version of RedHat Linux on all of our networked machines (of which there are a combination of 10 workstations and ~10 servers); something with this new installation did something to slowdown what I was doing previously. I can ssh into an independent machine where everything is local and my import times are comparable to what Martin got:
real 0m19.592s
user 0m12.269s
sys 0m3.116s
points=65000
This is a problem for me because I was dependent on using v.in.ascii for automatically processing some data and analyzing it in an operational setting. Looks like I have to find a new combination of machines to use within my environment.
Thanks for your help!
Tom
Martin Landa wrote:
2009/11/4 Hamish <hamish_b@yahoo.com>:
65k
in my case dbf (as default for 6.x).
Martin
Thomas E Adams
On Thu, Nov 5, 2009 at 1:33 AM, Thomas Adams <Thomas.Adams@noaa.gov> wrote:
Martin & Hamish,
<OT>
I guess that you use NFS. There are a few options to tune NFS, perhaps
during update your optimized settings got lost?
