I've a large text file of weather data. A sample row of data is:
station|name|lat|lon|elev|date|dapr|evap|mdpr|prcp|sn01|sn03|snow|snwd|sx01|sx03|wesd|wesf
USC00353770|Headworks Portland Water|45.4486|-122.1547|228.0|2005-01-01||||0.59|||0.0|0.0||||
The fourth column is longitude with values such as -122.1547. When I enter
this command:
in.ascii --overwrite \
in=/home/rshepard/projects/oregon/<project_name/data/precipitation/\
clackamas_co_weather_2005_2018.txt out=precip separator=pipe \
columns="station varchar, name varchar, y double precision, x double \
precision, elev double precision, date varchar, dapr double precision, \
evap double precision, sn01 double precision, sn03 double precision, \
snow double precision, snwd double precision, sx01 double precision, sx03 \
double precision, west double precision, wesf double precision" x=4 y=3 z=5
grass 7.5svn responds with this error:
Number of columns: 18
Number of rows: 113570
ERROR: 'x' column is not of number type
How do I specify west longitude without an initial '-' or an appended 'W'?
Rich
Don’t you need the “skip=1” parameter to skip the first header line of column names?
On 06/11/2018 08:55 PM, Rich Shepard wrote:
I’ve a large text file of weather data. A sample row of data is:
this command:
columns=“station varchar, name varchar, y double precision, x double
double precision, west double precision, wesf double precision” x=4 y=3 z=5
ERROR: ‘x’ column is not of number type
How do I specify west longitude without an initial ‘-’ or an appended ‘W’?
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
On Mon, 11 Jun 2018, Micha Silver wrote:
Don't you need the "skip=1" parameter to skip the first header line of
column names?
Micha,
I thought the header was used for attribute names in the database table.
Now, I realize that the columms variable does that, so I should add 'skip=1'
to the command. Yep. That was the problem and I missed seeing it.
Toda raba,
Rich
