[GRASS-user] v.in.ascii standard format CRS sequence
In v.in.ascii the point format specifies which data represents easting and
which represents northing by specifying which column is x and which is y,
respectively.
The standard format does not use column specifications. Is the standard
format assuming the sequence is easting/northing?
TIA,
Rich
Yep, Found the answer myself.
Rich
