I am trying to import an OpenOffice dbf into a wgs84
PERMANENT Location. I did this several times in the past
with older versions of GRASS. I enter all the necessary
information (input table, column names for x, y, z and
CAT#). The Connection tab shows "dbf" for the driver name
and database name reads "
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ "
I get this message:
DBMI-DBF driver error:
Table 'Iron_II_KNOWN_Sites' doesn't exist
Missing column <CAT> in table <Iron_II_KNOWN_Sites>
I will greatly appreciate any suggestions.
maybe it is case sensitive? try key=cat instead of key=CAT. ???
[SQL defines column names to be case insensitive, yes?? Did we ever find
that in a spec somewhere?]
# if you have `dbview` installed, what does this say:
dbview -e filename.dbf | head
To my knowledge no.
Because e.g. PostgreSQL support upper case column names but you have
to quote them. That's the source of the problem here maybe that
quoting is needed but cannot be propagated internally or so.
Personally I always avoid upper case columns and live happy with that.
