I imported a table with db.in.ogr of data set with 7 columns (see example below). Then I want to use V.IN.DB to create a new vector map with the 3D data set.
As the Name of Column (optional Tab), i used the “Particle” column as containing the category number, which is the attribute that i want to map. I get the error message that the data type should be an integer.
i have tried not setting the Category number as the attribute that i want to map, but then i get the message that xyz need to be integer in double. I am importing the file from csv file where the data points are as Numbers…
i really dont get it.
BHID |
ZONE |
EAST |
NORTH |
MASL |
PARTICLE |
MAT |
589424 |
17 |
612862 |
4846722 |
164 |
0.039 |
Silt |
589424 |
17 |
612862 |
4846722 |
163.7 |
0.02 |
Till |
589424 |
17 |
612862 |
4846722 |
163 |
0.02 |
Till |
(Thu Nov 08 05:38:42 2018)
v.in.db -t --overwrite table=GeomodNov8 x=EAST y=NORTH z=MASL key=PARTICLE output=geomodnov8
ERROR: Data type of key column must be integer
WARNING: Unable to delete file ‘C:\Users\Francois Chartier\Documents\grassdata\Toronto\Toronto\vector/geomodnov8/coor’
(Thu Nov 08 05:38:43 2018) Command finished (0 sec)
discard this email, i manage to import my data set with v.in.ascii instead.
Le jeu. 8 nov. 2018 à 05:54, Francois Chartier <fra.chartier@gmail.com> a écrit :
BHID |
ZONE |
EAST |
NORTH |
MASL |
PARTICLE |
MAT |
589424 |
17 |
612862 |
4846722 |
164 |
0.039 |
Silt |
589424 |
17 |
612862 |
4846722 |
163.7 |
0.02 |
Till |
589424 |
17 |
612862 |
4846722 |
163 |
0.02 |
Till |
