[GRASS-user] v.in.dxf crashes
Hi again,
I was trying to import some more vectors from my .dxf file and GRASS 6.4 crashed under Active tcl 8.5. I tried a simple layer and it still crashed. I got the message "The application Wish quit unexpectedly." I didn't have this problem with 6.3.
In Console Messages I get:
11/25/08 1:10:45 PM Terminal[8482] .sdef error: Operation could not be completed. (NSXMLParserErrorDomain error 1549.)
11/25/08 1:10:45 PM Terminal[8482] line number: 2
Hope this means something to someone.
Kurt
does it work if you try and run v.in.dxf from the command line?
(`wish` is the Tcl/Tk runtime..)
Hamish
It seemed to run fine in the command line. Running it through Wish causes it to crash.
Kurt
Hamish
it to crash.
I have tried v.in.dxf from current GRASS 6.4 on Linux and it worked for me.
So it might be related to Active tcl 8.5.
I don't think that the wish related part in GRASS 6.3 was different.
More likely, did you use a different Tcl version?
Searching in the net shows a couple of similar messages, apparently
related to Active tcl 8.5 (and not GRASS).
On GRASS 6.3 I use X11 on Mac OS X 10.5.5 (aka Leopard). I agree that the problem is with Active tcl 8.5. Having used the two, I have found X11 to be much more stable. How easy would it be to compile a 6.4 to use X11?
Kurt
it to crash.
Not hard at all...
Note that not only is the type of TclTk different - Aqua vs X11, but the version as well: 8.4 X11 for GRASS 6.3, 8.5 Aqua for GRASS 6.4. Maybe there is an issue with TclTk 8.5?
It's not possible to build a working (for GRASS) TclTk 8.4 Aqua - some Aqua issues were fixed in 8.5.
I guess the thing to try is TclTk 8.5 X11, to test if it's a version problem.
Do you have a small DXF that crashes for you that I could test with?
Check for a crashlog in Console.app. This could help. Especially since it would have some paths to verify which wish is running.
ActiveTcl or Aqua TclTk? (google didn't turn up anything for me)
sdef... that's scripting (Applescript) definitions for OSX (Wish.app is scriptable, to run a Tcl script). ... the AS dictionary for wish.app opens in Script Editor... Wish.app runs fine alone... hopefully a crashlog will help...
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
use X11?
Note that you don't need to re-compile anything to use a different
version of Tcl/Tk for gis.m. You just need to force it to use the
appropriate version of wish. Setting the GRASS_WISH environment
variable to point at a specic version of wish may be sufficient.
The only parts of GRASS which need to be compiled for a specific
version of Tcl/Tk are NVIZ, v.digit, and the form library used by
NVIZ, v.digit, d.what.vect and v.what.
Also, NVIZ needs to use the same "platform" for both Tcl/Tk and
OpenGL. You can't use --with-opengl=aqua with an X11 version of
Tcl/Tk, and vice versa.
wish is running.
In gis.m look in Help->About System for that.
Hamish
