I'm testing v.in.gpsbabel but I found a not corrspondence between tha datas
associated to the point in gps and the datas associated to the new vector.
In particular the label associated to the points (second column in the file
gps.csv, download by gpstrans) is not present in the table associated to the
vector (gpsbabel.dbf).
If I use a gps Garmin 12 (not Etrex) the label associated to the points
the vector (gpsbabel.dbf).
If I use gps Garmin 12 Etrex it works well (gpsbabel_etrex.dbf).
datas associated to the point in gps and the datas associated to the
new vector. In particular the label associated to the points (second
column in the file gps.csv, download by gpstrans) is not present in
the table associated to the vector (gpsbabel.dbf).
