[GRASS-user] v.in.gpsbabel
I am running 6.5 svn on Snow Leopard. I am trying to import points and tracks from a Garmin device (connected via USB). Using GPS Babel (v 1.4.1 for Mac), I prepared several files (.txt, .gdb, and .gpi) and tried to import these using v.in.gpsbabel (UTM wgs84 location) –k flag checked–. I am getting this error message:
ERROR: The gpsbabel program was not found, please install it first.
http://gpsbabel.sourceforge.net
As silly as it sounds, I am not sure if GPS Babel needs installing. After the download, a disk image appeared and double clicking launched the program (i.e., the window that retrieves data from the device and writes files). I did not install anything because it launched and it seems to be working (i.e., it writes files). I may be skipping some steps, so I will appreciate any suggestions.
BÜLENT
