Greetings,
I suppose this might be a GDAL issue, but several years ago when I imported SDTS DLG data in the UTM projection it properly created a projected location.
Now, running the same command(s) on the same data it creates a location that has no projection. I am importing the data with:
v.in.ogr -oe dsn=dlg/BD01CATD.DDF output=dlgBD location=43115g1_dlgBD
(with or without the -oe flag the results are the same)
Upon examining the 43115g1_dlgBD directory, I see that no PROJ_INFO or PROJ_UNITS file is created like it used to.
Examining the BD01XREF.DDF file, it states that the file is in UTM zone 11 projection (pertinent bits):
UTM NAS 11
Any suggestions how to import the data into a new projected location?
It seems odd that when I run:
ogrinfo -so /Volumes/lilBigy/projID/43115g1/DLG/BD/BD01CATD.DDF
It does not report any projection information:
ERROR 4: SDTS Driver doesn't support update.
Had to open data source read-only.
INFO: Open of `/Volumes/lilBigy/projID/43115g1/DLG/BD/BD01CATD.DDF'
using driver `OGR_SDTS' successful.
1: ABDF (None)
2: ACOI (None)
3: AHDR (None)
4: NP01 (Point)
5: NA01 (Point)
6: NO01 (Point)
7: LE01 (Line String)
8: PC01 (Polygon)
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
On 18/07/17 06:29, Jeshua Lacock wrote:
Greetings,
UTM NAS 11
1: ABDF (None)
2: ACOI (None)
3: AHDR (None)
4: NP01 (Point)
5: NA01 (Point)
6: NO01 (Point)
8: PC01 (Polygon)
Your file is multilayer. Try giving ogrinfo the name of one specific layer, i.e.
ogrinfo -so /Volumes/lilBigy/projID/43115g1/DLG/BD/BD01CATD.DDF NP01
and similarly with v.in.ogr
v.in.ogr -oe dsn=dlg/BD01CATD.DDF output=dlgBD location=43115g1_dlgBD layer=NP01
Moritz
