[GRASS-user] v.in.ogr ERROR: invalid byte sequence for encoding "UTF8": 0xae
   I use postgresql driver for GRASS. I have GRASS 6.2.2 installed in my
comp. with 'host=localhost,dbname=grass60test'.
When i try to import .shp files using v.in.ogr , i get the error...
HINT: This error can also happen if the byte sequence does not match the
encoding expected by the server, which is controlled by "client_encoding".
How do i correct it???
-Mohan
View this message in context: http://www.nabble.com/v.in.ogr-ERROR%3A--invalid-byte-sequence-for-encoding-"UTF8"%3A-0xae-tp15751969p15751969.html
