Hey Folks.
I was wondering someone else can test out this dataset and let me know if they can make it import…
Data source: http://www.geobase.ca/geobase/en/data/nrnc1.html
Province: Ontario
Archive: NRNC1_ON_SHAPE_en
File: ROADSEG
A free account is required to download the dataset.
System:
Linux (Gentoo)
Grass 6.0.2 and 6.1
Problem:
When importing regularly with attribute tables the process halts part way through. Not all the vectors are imported. There are lots of holes left in the dataset. The error was refering to incorrect format of a column….
Current Solution:
Importing vector shape without attribute table. All the vecotrs import without holes. However, of course I’d like to have the attribute tables
Next attempt to work around
Never tried anything like this before but I’ll try to just move the DBF file over to the DBF directory and try to connect to it manualy. I’m sure there will be a disconect somehow. If you have experience with this approach then let me know.
Thanks
David,
Does the attribute table contain any 'funny' characters ? anything that the
DBF driver or DBI driver would have problems with?
might try using a tool like dbfdump and awk to search for any oddities.
cheers,
dylan
On Thursday 10 August 2006 10:55, Sampson, David wrote:
Hey Folks.
if they can make it import...
Province: Ontario
File: ROADSEG
System:
Linux (Gentoo)
Grass 6.0.2 and 6.1
Problem:
column....
Current Solution:
without holes. However, of course I'd like to have the attribute tables
Never tried anything like this before but I'll try to just move the DBF
file over to the DBF directory and try to connect to it manualy. I'm
Thanks
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
