Hello Rich,
I don't have File GDB at hand to test it but it should be as simple as
pointing "input" to the folder of FGDB and setting "layer" to the name
of dataset in FGDB. You can get names of all layers in CLI with
"ogrinfo -ro -so /path/to/FGDB".
And if it works, perhaps it is worth adding an example to the help page? Or send a working code example that others can add to the help file of v.in.ogr if you like.
Hello Rich,
I don’t have File GDB at hand to test it but it should be as simple as
pointing “input” to the folder of FGDB and setting “layer” to the name
“ogrinfo -ro -so /path/to/FGDB”.
pointing "input" to the folder of FGDB and setting "layer" to the name of
dataset in FGDB. You can get names of all layers in CLI with "ogrinfo -ro
-so /path/to/FGDB".
Māris,
Something's wrong here. Using 'ogrinfo -ro -so Tile_E.gdb' from the
directory where that's located produces this message:
INFO: Open of `Tile_E.gdb/'
using driver `OpenFileGDB' successful.
Same result using -al rather than -ro.
Using the GUI:
Fri Sep 17 08:20:46 2021) v.in.ogr -r input=~/projects/washington/nevins-dock/data/bathymetry/Tile_E.gdb output=bathy_terrain
ERROR: Unable to open data source <[path_to_/Tile_E.gdb>
Is it me or v.in.ogr in the 8.0dev source?
A couple of years ago I had no problems importing ESRI FileGDB maps.
Strange. I just tested and it works just as I described:
v.in.ogr input=/home/maris/path/to/dataset.gdb/ layer=mylayer output=mylayer
I was testing on the main branch compiled at the end of August running
with GDAL 3.0.4.
Rich, you should see in the output of ogrinfo -ro -so a list of layers
in the FGDB. If you do not see them, then you will not be able to
import as GRASS is using OGR for reading FGDB.
Here's an example of output on my system:
ogrinfo -ro -so path/to.gdb/
INFO: Open of `to.gdb/'
1: first_layer (Multi Line String)
2: second_layer (Multi Polygon)
> -so /path/to/FGDB".
Māris,
Using the GUI:
with GDAL 3.0.4.
Maris,
gdal-3.2.2 is installed here. The problem is not that.
That's what I expected. But, From the directory in which Tile_E.gdb/ is
located:
$ ogrinfo -ro -so ./Tile_E.gdb/
INFO: Open of `./Tile_E.gdb/'
That's it.
Of course GRASS could not import it since ogrinfo didn't see any content in
the open file.
import lay layer using drag and drop into QGIS. From there to GRASS GIS
(import QGIS layer).
Klaus,
I don't run QGIS. GRASS and SAGA GIS meet my needs. It's also likely that if
ogr opens the directory but does not find any files it won't on QGIS either.
I saw that you found a different solution, but just for the record: are you sure the fgdb actually contains vector data ? AFAIR, fgdb's can also contain raster data, but there is no gdal driver for that.
Moritz
Le 17 septembre 2021 19:29:37 GMT+02:00, Rich Shepard <rshepard@appl-ecosys.com> a écrit :
with GDAL 3.0.4.
Maris,
located:
That's it.
the open file.
Moritz,
The alternative solution is less desirable.
I've no idea how to determine if the fileGDB holds vector or raster data.
I've looked through the gdal web site and didn't see how to determine the
type of data. But, I've assumed the .atx files in the directory ar vector.
There are also several TIFF files:
tile_e_dem_tif.aux.xml
tile_e_dem_tif.tfw
tile_e_dem_tif.tif
tile_e_dem_tif.tif.ovr
tile_e_dem_tif.tif.xml
I've not tried r.in.gdal; will do so over the weekend.
BTW, I don't know what Vero changed in the web site but for the 8.0dev
manual the GRASS startup page link in the General category still produces a
404 page not found.
