[GRASS-user] v.in.ogr fails to write a postgres attribute table when importing from a coverage
When I try to import from a polygon coverage, using the command
v.in.ogr dsn=blcf_bec layer=PAL out=bec
I get the these warnings and errors:
WARNING: Writing column <ArcIds> with fixed length 40 chars (may be
         truncated)
WARNING: Column name changed: 'BLCF_BEC#' -> 'BLCF_BEC_'
WARNING: Column name changed: 'BLCF_BEC-ID' -> 'BLCF_BEC_ID'
Importing map 18 features...
DBMI-Postgres driver error:
Cannot execute:
insert into bec values ( 3,
'(22:10,-17,-18,-26,28,31,32,33,36,40,44,57,62,65,64,-60,-41,34,30,27,22,11)',
116724105.46633, 162901.07239, 4, 3982, 'SBS dk', 'SBS', 'dk', '',
'', 'FI00000000', 'D3' )
ERROR: value too long for type character varying(40)
ERROR: Cannot insert new row: insert into bec values ( 3,
As I see it, the ArcIds field is properly truncated when writing to a
dbf, but fails in Postgres. Is there an easy way to prevent this field
from being written at all?
Thanks
David
