[GRASS-user] v.in.ogr from PostGIS - how to avoid primary key to become cat
Dear list,
sorry for writing several times in such a short time, but every start is a little hard....
When importing from PostGIS, v.in.ogr will remove the column with the primary key and use the objects as "cat". Is there a way to avoid this behaviour, e.g a flag?
I just copied the table now in SQL, and imported the copy, but I guess that is not really the best way to handle this.
During my search I found a post to the mailing-list from 2008 on this issue, but no answer to that one.
patrick
