Anyone else having issues getting ‘v.in.ogr’ to bring in Postgres/PostGIS layers. This happens when you select ‘Database’ then ‘Format: PostgreSQL’ then ‘Name:your_database_name’ no list of vector layers appear. Have used the new ‘db.login’ settings for ‘Hostname’ and ‘Port’ so at least i’m not getting the old error about incorrect password.
2016-04-22 13:59 GMT+02:00 Paul Shapley <p.shapley@gmail.com>:
Anyone else having issues getting 'v.in.ogr' to bring in Postgres/PostGIS
layers. This happens when you select 'Database' then 'Format: PostgreSQL'
then 'Name:your_database_name' no list of vector layers appear. Have used
the new 'db.login' settings for 'Hostname' and 'Port' so at least i'm not
I think this issue is fixed in trunk (as far as I undertood your report). Martin
