[GRASS-user] v.in.ogr in Python Grass script
Michel,
thank you very much for your answer. In my little script, there are more lines above that come from the wiki you referenced, too. I did not want to write them all down here in order to keep it short. Without the environment setup, I got messages like "no such module" when trying to call Grass. But that was the easier part (although hard enough for me, too :slight_smile: because I had messages.
Now the problem is that things start working (v.in) and then it crashes without any message. So I have not idea what could be wrong.
Do you really think that Grass 7 makes a diff? The menu command in 6.4.4 works fine. That's confusing to me.
Mit freundlichen Grüßen,
UWE FISCHER
Von: grass-user [mailto:grass-user-bounces@lists.osgeo.org] Im Auftrag von grass-user-request@lists.osgeo.org
Gesendet: Donnerstag, 3. März 2016 14:31
An: grass-user@lists.osgeo.org
Betreff: grass-user Digest, Vol 119, Issue 4
Send grass-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of grass-user digest..."
Today's Topics:
   1. Change GRASS region multiple times (Luna, Daniel Eduardo)
   2. Re: stream network (Stefan Lüdtke)
   3. v.in.ogr in Python script not working (Uwe Fischer)
   4. Re: v.in.ogr in Python script not working (Michel Wortmann)
Message: 1
Date: Wed, 2 Mar 2016 21:40:05 +0000
To: "grass-user@lists.osgeo.org" <grass-user@lists.osgeo.org>
Cc: "Liang, Xu" <xuliang@pitt.edu>, "Hernandez Cruz, Felipe"
  <FEH17@pitt.edu>
Subject: [GRASS-user] Change GRASS region multiple times
Message-ID:
  <BN3PR0401MB16395B804C952062E8FA8974D7BC0@BN3PR0401MB1639.namprd04.prod.outlook.com>
Content-Type: text/plain; charset="iso-8859-1"
Hello!
I'm working with pygrass, developing a new module for GRASS.
I need to create a new raster map during the execution. I'm using the commands:
        from grass.pygrass import raster
        newRasterMap = raster.RasterSegment('new')
        newRasterMap.open('w', 'CELL')
I've noticed that new raster maps are created with the resolution of the current region in GRASS. I've noticed also that it is possible to change the current region during the execution of my new module using the script 'g.region'. However, it looks like if I want to change the resolution again, the script 'g.region' does not have any effect. My conclusion: GRASS can change the current region just 1 time during the execution of a module. Is that correct?
I would like to know how can I develop a new module (using pygrass) where I could be able to create three new raster maps with different resolutions each?
Thank you all very much!
Dan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160302/84eb7d6e/attachment-0001.html&gt;
Message: 2
Date: Thu, 3 Mar 2016 10:38:42 +0100
To: Janet Choate <jsc.eco@gmail.com>, Will Fields
  <will.openfields@gmail.com>
Cc: grass list <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] stream network
Message-ID: <56D80622.1070103@gfz-potsdam.de>
Content-Type: text/plain; charset="utf-8"
Hi Janet,
can you provide a screenshot of the river network, I think that helps to understand what is going on in your specific case?!
Stefan
On 02/03/16 20:42, Janet Choate wrote:
Hi Will,
When running r.watershed on a small 35 hectare watershed, it produces
a fully connected stream network. However, when running r.watershed on
a
6400 hectare watershed, the stream network is not fully connected.
No preprocessing with regards to merging different raster maps,
however, I did try using r.fill.dir first to deal with any possible
depressions that might be causing non-connected stream segments.
thanks,
Janet
On Wed, Mar 2, 2016 at 11:22 AM, Will Fields
<will.openfields@gmail.com <mailto:will.openfields@gmail.com>> wrote:
    Hi Janet,
    Can you give some more information about what you mean by larger
    watershed basins? Did you do any preprocessing of the elevation
    raster before you tried to extract the stream networks? Were you
    using an elevation raster that had been merged from different
    rasters? I've ran into issues in the past where "seams" along the
    original edges of a raster resulted in odd stream networks.
    Will
    On Wed, Mar 2, 2016 at 11:40 AM, Janet Choate <jsc.eco@gmail.com
    <mailto:jsc.eco@gmail.com>> wrote:
        Hi GRASS community,
        When creating a stream network with r.watershed, I end up with
        some isolated stream segments - particularly in larger watershed
        basins. Does anyone know how to generate a stream network that
        is fully connected, or how to correct this issue?
        thank you,
        Janet
        grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
Tague Team Lab Manager
1005 Bren Hall
UCSB, Santa Barbara, CA.
Stefan Lüdtke
Section 5.4- Hydrology
Tel.: +49 331 288 2821
Fax: +49 331 288 1570
Email: sluedtke@gfz-potsdam.de
Helmholtz-Zentrum Potsdam
Deutsches GeoForschungsZentrum GFZ
(GFZ German Research Centre for Geoscience) Stiftung des öff. Rechts Land Brandenburg Telegrafenberg, 14473 Potsdam
PGP Public Key: http://bit.ly/13d9Sca
Type: application/pgp-signature
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160303/a325b3ed/attachment-0001.sig&gt;
Message: 3
Date: Thu, 3 Mar 2016 13:35:50 +0100
To: <grass-user@lists.osgeo.org>
Subject: [GRASS-user] v.in.ogr in Python script not working
Message-ID: <003f01d17549$38babe80$aa303b80$@t-online.de>
Hello,
I' new to this list and this is my first question. I try to develop a script that is able to import CAD files (MicroStation DGN) into a grass mapset.
First, I tried the command v.in.ogr in the menu system and everything works fine. The result is exactly as desired. Then, I tried to write a Python script that is able to do exactly the same but without starting GRASS.
The command line provided by the menu input (in QGIS' Grass toolbox) reads:
v.in.ogr dsn=D:/my.dgn output=gr03 type=boundary,centroid snap=0.01
min_area=1 "where="Level" = 1" -o
Searching the internet for sample scripts, I found some of those and modified my command string according to the samples:
import grass.script as grass
import grass.script.setup as gsetup
gsetup.init(gisbase,gisdbase,location,mapset)
input_dgn = "D:\\my.dgn"
grass.run_command("v.in.ogr",
                  dsn = input_dgn,
                  output = 'gr03',
                  type = 'boundary,centroid',
                  snap = 0.01,
                  min_area = 1,
                  where = """"Level" = 1""")
Unfortunately, this does not work. I get an error crash message telling me that v.in.ogr does not work any more. I tried many different options, including other use of quotes or leaving some args off. Nothing helped.
Maybe there is a keyword conflict or an issue with the order of the args?
The "where" part is very important since it helps me split the data like i need to. I use Grass 6.4.4
Thanks a lot for help an ideas,
Regards, Uwe
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160303/a38bba02/attachment-0001.html&gt;
Message: 4
Date: Thu, 3 Mar 2016 14:24:27 +0100
To: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] v.in.ogr in Python script not working
Message-ID: <56D83B0B.4010506@pik-potsdam.de>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Hi Uwe,
I think you are missing a few environment setup steps if you want to start your python script without starting grass. Here is all you need, although this wiki refers to GRASS7. The grass.setup.init is not enough.
https://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
But I highly recommend upgrading to GRASS7 anyways. Only the v.in.ogr argument dsn has been changed to input.
Hope it helps.
Best,
Michel
On 03/03/2016 01:35 PM, Uwe Fischer wrote:
Hello,
I‘ new to this list and this is my first question. I try to develop a
grass mapset. First, I tried the command v.in.ogr in the menu system
The command line provided by the menu input (in QGIS‘ Grass toolbox)
reads:
min_area=1 "where="Level" = 1" –o
                  dsn = input_dgn,
                  output = 'gr03',
                  snap = 0.01,
                  min_area = 1,
off. Nothing helped. Maybe there is a keyword conflict or an issue
with the order of the args? The „where“ part is very important since
Regards, Uwe
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160303/30d26eac/attachment.html&gt;
Subject: Digest Footer
End of grass-user Digest, Vol 119, Issue 4
Hi Uwe,
I can really only speak for GRASS7 (and I would almost say this is the way to go). You'll need to give us a working script plus your error messages/tracebacks. Have you tried running your script inside a grass session either from the commandline or inside the python shell that comes with the gui?
Best,
Michel
On 03/03/2016 03:57 PM, Uwe Fischer wrote:
Michel,
UWE FISCHER
Today's Topics:
Message: 1
  <FEH17@pitt.edu>
Message-ID:
Hello!
Dan
Message: 2
Hi Janet,
Stefan
Hi Will,
a
thanks,
Janet
     Hi Janet,
     Will
         Hi GRASS community,
         thank you,
         Janet
1005 Bren Hall
Stefan Lüdtke
Message: 3
Hello,
                   dsn = input_dgn,
                   output = 'gr03',
                   snap = 0.01,
                   min_area = 1,
Regards, Uwe
Message: 4
Hi Uwe,
Hope it helps.
Best,
Michel
Hello,
reads:
                   dsn = input_dgn,
                   output = 'gr03',
                   snap = 0.01,
                   min_area = 1,
Regards, Uwe
Hi Michel, hi List,
In addition to my question from yesterday (concerning v.in.ogr in a Python script), today another item shows up.
I removed the old QGIS from my notebook and installed 2.14 with Grass 7 in order to try that version (following Michels advice). But now I can't get the script running at all. I get an "import error: no module named site" message. The same when I just type "python" at the dos prompt.
I appended the following to the search path (hoping that puts Python to work), but it did not help:
  C:\Program Files\QGIS Essen\apps\Python27;
  C:\Program Files\QGIS Essen\apps\Python27\Lib;
  C:\Program Files\QGIS Essen\bin
I wonder if the reason is that on the notebook, there is no ordinary Python Installation (Python outside QGIS and GRASS). On my desktop PC (where the script starts fine but crashes before producing output), there is an installation under C:\Python27. There, I get no such error.
Looks like I have no basic understandig for this. So please let me know: are the Python parts that come with QGIS and GRASS a complete Python installation? Or do I have to run an additional Python setup outside QGIS and GRASS to get external scripts running (external script means: scripts that use GRASS commands from outside a GRASS session)??? Maybe the Python parts that get installed along with the GIS are just for internal Python scripting purposes inside QGIS and GRASS sessions?
And if the Python parts of QGIS and GRASS are sufficient for my purpose, how do I have to complete the system setup to get things running (additional path variables? What the h* is "Pythonpath" for? And how to start IDLE?)
Greets, Uwe
Von: Michel Wortmann [mailto:wortmann@pik-potsdam.de]
Gesendet: Donnerstag, 3. März 2016 17:14
Cc: Uwe Fischer <gisfisch@t-online.de>
Betreff: Re: v.in.ogr in Python Grass script
Hi Uwe,
Best,
Michel
Michel,
UWE FISCHER
Today's Topics:
Message: 1
  <FEH17@pitt.edu>
Message-ID:
d.outlook.com>
Hello!
Dan
-------------- next part -------------- An HTML attachment was
scrubbed...
URL:
7d6e/attachment-0001.html>
Message: 2
Hi Janet,
Stefan
Hi Will,
on a
thanks,
Janet
     Hi Janet,
     Will
         Hi GRASS community,
         thank you,
         Janet
1005 Bren Hall
Stefan Lüdtke
-------------- next part -------------- A non-text attachment was
scrubbed...
URL:
b3ed/attachment-0001.sig>
Message: 3
Hello,
                   dsn = input_dgn,
                   output = 'gr03',
                   snap = 0.01,
                   min_area = 1,
Regards, Uwe
scrubbed...
URL:
ba02/attachment-0001.html>
Message: 4
Hi Uwe,
t_explicitly But I highly recommend upgrading to GRASS7 anyways. Only
Hope it helps.
Best,
Michel
Hello,
reads:
                   dsn = input_dgn,
                   output = 'gr03',
                   snap = 0.01,
                   min_area = 1,
Regards, Uwe
scrubbed...
URL:
6eac/attachment.html>
Hi Michel,
I know that this is not a QGIS list. I am member of the QGIS list and believe me, if I ask my original question there, they will tell me that it is a GRASS question (which is true).
Now, I can't go on without Windows or QGIS and so I can't see the point in changing the installation again.
Could somebody try my few lines of code (please see attachment) in a stable GRASS environment in order to find out if the module call for v.in.ogr is working and creating output?
I'm pretty sure that there is something wrong in the way v.in.ogr is used in the script, and maybe somebody can tell me what it is. Maybe the triple quotes or something. I have no idea because there is no output and no message.
UWE FISCHER
Gesendet: Freitag, 4. März 2016 11:35
An: Uwe Fischer <gisfisch@t-online.de>
Betreff: Re: AW: v.in.ogr in Python Grass script
Hi Uwe,
I would advice you to install grass as a standalone installation, this is how must of us here use it and this is not really a QGIS list. There is plenty of documentation out there on setting winGRASS up with Python (https://grass.osgeo.org/download/software/ms-windows/
https://grasswiki.osgeo.org/wiki/GRASS_and_Python) . I'm a Linux user so I cant help you with that.
Best,
Michel
On 03/04/2016 11:09 AM, Uwe Fischer wrote:
Hi Michel, hi List,
Greets, Uwe
Hi Uwe,
Best,
Michel
Michel,
UWE FISCHER
Today's Topics:
Message: 1
  <FEH17@pitt.edu>
Message-ID:
o
d.outlook.com>
Hello!
Dan
scrubbed...
URL:
b
Message: 2
Hi Janet,
Stefan
Hi Will,
produces a fully connected stream network. However, when running
r.watershed on a
thanks,
Janet
      Hi Janet,
      Will
          Hi GRASS community,
          thank you,
          Janet
1005 Bren Hall
Stefan Lüdtke
scrubbed...
URL:
5
Message: 3
Hello,
                    dsn = input_dgn,
                    output = 'gr03',
                    snap = 0.01,
                    min_area = 1,
Regards, Uwe
scrubbed...
URL:
b
Message: 4
Hi Uwe,
i t_explicitly But I highly recommend upgrading to GRASS7 anyways.
Hope it helps.
Best,
Michel
Hello,
reads:
                    dsn = input_dgn,
                    output = 'gr03',
                    snap = 0.01,
                    min_area = 1,
args off. Nothing helped. Maybe there is a keyword conflict or an
issue with the order of the args? The „where“ part is very important
Regards, Uwe
scrubbed...
URL:
2
(attachments)
my_input.dgn (172 KB)
testscript.py (691 Bytes)
On 04/03/16 11:09, Uwe Fischer wrote:
Hi Michel, hi List,
dos prompt.
C:\Program Files\QGIS Essen\apps\Python27; C:\Program Files\QGIS
Essen\apps\Python27\Lib; C:\Program Files\QGIS Essen\bin
error.
Complete, but not sytem-wide.
session)???
Yes, you have to set PYTHONPATH.
PYTHONPATH is a variable that contains the information about where to find python libraries.
Check this: https://grasswiki.osgeo.org/wiki/GRASS_and_Python#MS-Windows
AFAIK, IDLE is not installed.
Moritz
[Please keep mails on the list]
On 04/03/16 17:38, Uwe Fischer wrote:
Moritz,
thank you very much for your answer. In the wiki doc you mentioned, there are two entries for exactly the same folder (PATH and PYTHONPATH). In case of PATH, there are additional folders:
PATH= C:\GRASS-64\etc;C:\GRASS-64\etc\python;C:\GRASS-64\lib;C:\GRASS-64\bin;C:\GRASS-64\extralib;C:\GRASS-64\msys\bin;C:\Python26;
PYTHONPATH= C:\GRASS-64\etc\python
I'd love to find out the difference between PATH an PYTONPATH and its meaning.
Google 'PATH vs PYTHON PATH' to find many entries on the subject.
Very briefly:
PATH lists the directories where the system can find the executables of programs.
PYTHONPATH lists the directors where Python can find python modules.
Within a Python script sys.path is initialized with the content of PYTHONPATH.
Moritz
