I want to read a 3d shape. Unfortunately, it does not finish (killed
after 2 hours!). Qgis is able to import it although I guess it is done
in 2d what grass is also capable of without the -z switch. Here is the
output with grass 6.4.1:
v.in.ogr --v -z dsn=St_Flaeche_3D.shp out=basel3d
Projection of input dataset and current location appear to match
Using temporary vector <basel3d_tmp>
Layer: St_Flaeche_3D
Counting polygons for 1192679 features...
Boundary splitting distance in map units: 176.386
Importing map 1192679 features...
100%
Building topology for vector map <basel3d_tmp>...
Registering primitives...
397678 primitives registered
1549444 vertices registered
Topology was built
Number of nodes: 268594
Number of primitives: 397678
Number of points: 0
Number of lines: 0
Number of boundaries: 397678
Number of centroids: 0
Number of areas: -
Number of isles: -
WARNING: Cleaning polygons, result is not guaranteed!
Break polygons:
100%
100%
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 239035
Remove duplicates:
100%
Clean boundaries at nodes:
Break boundaries:
100%
Intersections: 22
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 0
Remove duplicates:
100%
Change dangles to lines:
100%
Remove bridges:
99%
Here it stops to produce output but still there is 100% CPU usage. Any idea?
Thank you
Sebastian
Sebastian Schubert wrote:
100%
Topology was built
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Break polygons:
100%
100%
Remove duplicates:
100%
Break boundaries:
100%
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 22
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 0
Remove duplicates:
100%
100%
Remove bridges:
99%
Yes. It takes very long because of a high number of potential bridges.
This can happen with some larger vector files and processing speed has
been improved in 6.4.2 and above. Please try 6.4.2RC1 if possible.
Markus M
You have 3D polygons in your input data.
Getting 3D polygon data into GRASS can be
tricky.
Since GRASS uses a 2D topology model for
polygons, it will butcher all 3D polygons that
do not overlap in 3D space, but do so from a 2D
perspective. It will also have trouble with
polygons that extend only along the Z axis
and have no X-Y area.
Even if you manage to get the data into
GRASS using v.in.ogr's "-c" flag, you won't
be able to do much with it, because the result
will not have a valid GRASS topology.
If import into GRASS fails, you basically
have two choices:
1. Import polygons as polylines (use the
"type" option in v.in.ogr). But that of
course will modify your geometries.
2. Use GRASS7 and v.external to attach
the Shapefile directly (GRASS 6.4 cannot
attach 3D vector data sources).
Best,
Ben
Btw. QGIS has a strictly 2D vector data model, so
that won't get you anywhere.
Using temporary vector<basel3d_tmp>
100%
Building topology for vector map<basel3d_tmp>...
Topology was built
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Break polygons:
100%
Remove duplicates:
100%
Break boundaries:
100%
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 22
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 0
Remove duplicates:
100%
100%
Remove bridges:
99%
Markus M
grass-user mailing list
grass-user@lists.osgeo.org
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
benducke@fastmail.fm
