[GRASS-user] v.in.ogr of shp file: no centroids but data in table
I imported a shape file into grass
v.in.ogr --o basel_gelaende.shp out=basel_gelaende
resulting in:
Number of nodes: 38602
Number of primitives: 115042
Number of points: 0
Number of lines: 0
Number of boundaries: 115042
Number of centroids: 0
Number of areas: 76441
Number of isles: 1
Number of areas without centroid: 76441
If I understood the grass book correctly, the table cat column and with
that the whole table is connected via the centroids. That would explain
that I don't see any information from the table when I use v.what:
Building spatial index...
East: 7:34:46.8228E
North: 47:34:23.9952N
Map: basel_gelaende
Mapset: Basel
Type: Area
Sq Meters: 32796.147
Hectares: 3.280
Acres: 8.104
Sq Miles: 0.0127
I could do a v.centroids to calculate the centroids and then also v.what
gives information from the table, but the data is not correct. I guess
grass put the cat values without really knowing the right connection.
It might be important that the map is actually a 3d one, but in "2d
mode" so I got the following warning:
WARNING: Input data contains 3D features. Created vector is 2D only, use
-z flag to import 3D vector
I can import the map in qgis and it works, I do have the right
connection between polygons and table rows. I tried to include
"centroid" in the type parameter of v.in.ogr, but this did not have any
effect for me.
Any idea?
Thanks a lot
Sebastian
Sebastian Schubert wrote:
resulting in:
Number of points: 0
Number of lines: 0
Number of isles: 1
What version of GRASS are you using? There are slight differences in
v.in.ogr between 6.4.0, 6.4.1, 6.4.2, although these should not affect
centroid creation. Are you using GRASS directly or through e.g. the
QGIS-GRASS plugin? And can you post the full output of v.in.ogr --v?
At some stage, centroids are calculated for input polygons, and the
corresponding messages would be helpful.
Yes, this must be determined during import.
No, this should not affect the output. Unless the input shapefile is
real 3D with vertical polygons that have zero area size when projected
onto the x,y plane. 2.5D polygons are fine.
Markus M
resulting in:
Number of points: 0
Number of lines: 0
Number of isles: 1
centroid creation.
6.4.1
QGIS-GRASS plugin?
Directly.
This is the output for the shape filed attached:
GRASS 6.4.1 (WGS84):~/temp/basel > v.in.ogr --v polygon.shp out=polygon
Projection of input dataset and current location appear to match
Using temporary vector <polygon_tmp>
Layer: polygon
Counting polygons for 1 features...
Importing map 1 features...
100%
Building topology for vector map <polygon_tmp>...
Registering primitives...
1 primitives registered
4 vertices registered
Topology was built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
WARNING: Cleaning polygons, result is not guaranteed!
Break polygons:
100%
100%
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 0
Remove duplicates:
100%
Clean boundaries at nodes:
Change dangles to lines:
100%
Remove bridges:
100%
Merge boundaries:
100%
0 boundaries merged
0 new boundaries
Building areas...
100%
1 areas built
1 isles built
Attaching islands...
100%
Topology was built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Number of areas without centroid: 1
Find centroids for layer: polygon
Write centroids:
100%
1 input polygons
Total area: 19263.4 (1 areas)
Overlapping area: 0 (0 areas)
Area without category: 19263.4 (1 areas)
Building topology for vector map <polygon>...
Building areas...
100%
1 areas built
1 isles built
100%
Attaching centroids...
100%
Topology was built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
WARNING: Input data contains 3D features. Created vector is 2D only, use -z
Similar problem.
I used Qgis to just keep one polygon. In Qgis, I can see the connected
table with the values "OBJID", "ART", "ART_TXT", "Z_MIN", "Z_MAX",
"Z_MEAN", "LENGTH_3D", "MIN_SLOPE", "MAX_SLOPE", "AVG_SLOPE", "VERTEX_CNT".
Thanks!
Sebastian
(attachments)
polygon.zip (1.43 KB)
On Tue, Oct 18, 2011 at 7:38 PM, Sebastian Schubert
resulting in:
Number of points: 0
Number of lines: 0
Number of isles: 1
centroid creation.
6.4.1
QGIS-GRASS plugin?
Directly.
Layer: polygon
100%
Topology was built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: -
Number of isles: -
Break polygons:
100%
100%
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 0
Remove duplicates:
100%
100%
Remove bridges:
100%
Merge boundaries:
100%
0 boundaries merged
0 new boundaries
Building areas...
100%
1 areas built
1 isles built
100%
Topology was built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Write centroids:
100%
1 input polygons
Building areas...
100%
1 areas built
1 isles built
100%
100%
Topology was built
Number of nodes: 1
Number of points: 0
Number of lines: 0
Number of areas: 1
Number of isles: 1
Similar problem.
Thanks for the sample polygon. I could reproduce it, have found the
bug and fixed it in r48850-2 (all branches).
Markus M
On Wednesday 19 October 2011 08:51:35 Markus Metz wrote:
[no centroids when importing]
Thanks a lot for this very fast fix. It works for me!
Sebastian
