[GRASS-user] v.in.ogr python-loop
Dear list,
Tried to import about 400.000 polygons through v.in.ogr from a PG-database (basically shp-file). After 2 days the process got aborded as you can see below. Supposedly the memory of my computer is not big enough- at 51% of boundary break 1.7GB of memory where used.
So I would like to try import by looping and patching in a python-script. I only started recently to combine GRASS with python and don't know much of python at all, but I imagine this script should do the job. Unfortunately the "Flags" are not recognized, although I tried it in various ways "Flags, flags, flag, Flag, F". I will always get a Feedback of "ERROR: Projection of dataset does not appear to match current location....." which I want do ignore by using the flag "-o".
Any idea?
greetz, Patrick
##########PYTHONSCRIPT FOR LOOP####################################
#!/usr/bin/env python
#scipt is only help
#will import through loop
import os
import sys
import grass.script as grass
def main():
     i=0
     n=0
     while i<2:
         i=i+1
         i=str(i)
         grass.run_command(
             'v.in.ogr', dsn="PG:dbname=schirpat", Flags="-o",
             layer="sc.av_liegensch", output="GR_ZH_av_liegensch_poly"+i,
             type="boundary,centroid", where="bfs="+i)
         GRASS GIS.run.command(
             #'v.patch', input="GR_ZH_av_liegensch_poly"+i",GR_av_liegensch_poly", output="GR_av_liegensch_poly", Flags="--overwrite")
if __name__ == "__main__":
    main()
##############PREVIOUS DIRECT IMPORT VIA SHELL#########################
GRASS 7.0.svn (Survey):~ > v.in.ogr "dsn=PG:dbname=schirpat" layer=sc.av_liegensch output=GR_ZH_av_liegensch_poly type=boundary,centroid -o --o
Warning 1: Multi-column primary key in 'gwr_strassen' detected but not supported.
Warning 1: Multi-column primary key in 'tt_iv' detected but not supported.
Warning 1: Multi-column primary key in 'gwr_adressen' detected but not supported.
Warning 1: Multi-column primary key in 'tt_oev' detected but not supported.
Warning 1: Multi-column primary key in 'gwr_wohnungen' detected but not supported.
Over-riding projection check
Layer: sc.av_liegensch
Counting polygons for 367314 features...
Importing map 367314 features...
  100%
Building topology for vector map <GR_ZH_av_liegensch_poly_tmp@survey>...
Registering primitives...
382467 primitives registered
27795398 vertices registered
Number of nodes: 369522
Number of primitives: 382467
Number of points: 0
Number of lines: 0
Number of boundaries: 382467
Number of centroids: 0
Number of areas: -
Number of isles: -
WARNING: Cleaning polygons, result is not guaranteed!
Break polygons:
  100%
Remove duplicates:
  100%
Break boundaries:
  100%
Remove duplicates:
  100%
Clean boundaries at nodes:
  100%
Break boundaries:
Unexpected error.
Aborted
