[GRASS-user] v.in.ogr to SDE
Hi
I have grass installed using the osgeo4w. Am trying to use the v.in.ogr command to import some vector data from an ESRI SDE data source.
I have successfully used the OGR2OGR utility that came installed with the ogeo4w to extract vector data from SDE to a shapefile. When I open op a osgoe4w command prompt and query the formats supported I get the following list:
C:\Windows\system32>ogrinfo --formats
Supported Formats:
→ “OCI” (read/write)
→ “SDE” (readonly)
→ “ESRI Shapefile” (read/write)
→ “MapInfo File” (read/write)
→ “UK .NTF” (readonly)
→ “SDTS” (readonly)
→ “TIGER” (read/write)
→ “S57” (read/write)
→ “DGN” (read/write)
→ “VRT” (readonly)
→ “REC” (readonly)
→ “Memory” (read/write)
→ “BNA” (read/write)
→ “CSV” (read/write)
→ “GML” (read/write)
→ “GPX” (read/write)
→ “KML” (read/write)
→ “GeoJSON” (read/write)
→ “Interlis 1” (read/write)
→ “Interlis 2” (read/write)
→ “GMT” (read/write)
→ “SQLite” (read/write)
→ “ODBC” (read/write)
→ “PGeo” (readonly)
→ “OGDI” (readonly)
→ “PostgreSQL” (read/write)
→ “MySQL” (read/write)
→ “AVCBin” (readonly)
Yet when I try to use the v.in.ogr command with the following syntax I get the error: Unable to open data source. The following is a summary of the syntax that I am using:
v.in.ogr dsn=SDE:habs.ca,5153,ordb1,oraUserName,password,MYSCHEMA.LOCATIONS output=LOCATIONS
Is there any way I can verify that the grass is using the same GDAL/OGR versions as I am using on the OSGEO4W command line?
Any help would be appreciated.
Thanks
Fran
