I’m using v.in.ogr with the location option. The new location is created correctly, and the projection is set to the one defined by my shapefile’s .prj file, but no data is imported. The mapset is empty.
The command line reports the following message:
WARNING: All available OGR layers will be imported into vector map
<centroidi_province>
Location created
The same command launched in a preexisting location (and without the location option) works fine and the data is correctly imported.
giovanni
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/giohappy
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
I forgot to say that I’m using grass 7 on a Ubuntu machine
2015-02-18 13:06 GMT+01:00 G. Allegri <giohappy@gmail.com>:
Location created
giovanni
Giovanni Allegri
Giovanni Allegri
On Wed, Feb 18, 2015 at 7:07 AM, G. Allegri <giohappy@gmail.com> wrote:
I forgot to say that I'm using grass 7 on a Ubuntu machine
I'm using v.in.ogr with the location option. The new location is created
correctly, and the projection is set to the one defined by my shapefile's
Location <workLocation> created
Hm, it is working for me in G70 and G71 (Ubuntu as well):
v.in.ogr
input=/home/anna/grassdata/data/shoreline_oceanfront_1998/Shoreline_Oceanfront_1998.shp
output=test location=testLoc
Location <testLoc> created
Check if OGR layer <Shoreline_Oceanfront_1998> contains polygons...
100%
Importing 21 features (OGR layer <Shoreline_Oceanfront_1998>)...
100%
Building topology for vector map <test@PERMANENT>...
Registering primitives...
67 primitives registered
19183 vertices registered
Building areas...
100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
100%
Number of nodes: 128
Number of primitives: 67
Number of points: 0
Number of lines: 67
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
Anna
giovanni
Giovanni Allegri
Twitter: https://twitter.com/_giohappy_
Giovanni Allegri
grass-user mailing list
grass-user@lists.osgeo.org
Thanks Anna,
yuor example gave me the hint: I didn’t set the output parameter, which I thought could be obtained from the input dataset name.
giovanni
2015-02-18 15:28 GMT+01:00 Anna Petrášová <kratochanna@gmail.com>:
v.in.ogr input=/home/anna/grassdata/data/shoreline_oceanfront_1998/Shoreline_Oceanfront_1998.shp output=test location=testLoc
Location created
Check if OGR layer <Shoreline_Oceanfront_1998> contains polygons…
100%
Importing 21 features (OGR layer <Shoreline_Oceanfront_1998>)…
100%
Building topology for vector map test@PERMANENT…
Registering primitives…
Building areas…
100%
0 areas built
0 isles built
Attaching islands…
Attaching centroids…
100%
Number of points: 0
Number of lines: 67
Number of areas: 0
Number of isles: 0
Anna
Location created
giovanni
Giovanni Allegri
Giovanni Allegri
Giovanni Allegri
