[GRASS-user] v.in.ogr
Hi.
I have the following problem with a Shape-file. First the history: I
imported once a ascii-file, then i exported it to a shape-file. Then I
changed some values with QGis and now I would like to re-import the file
(shp). So I used the command v.in.ogr.
v.in.ogr {dsn=/home/....../Städte Noricum Romanum5.shp}
output=Staedte_Noricum min_area=0.0001 snp=-1
And the Result is (I tried to translate it to english):
Spaltenname wurde geändert: 'cat' -> 'cat_' (in english: Column-name
changed: 'cat' -> 'cat_')
DBMI-DBF driver error:
Column 'cat_' already exists (duplicate name)
Cannot create table.
Error in db_execute_immediate()
Kann Tabelle nicht erzeugen (in english: Could not create table):
'create table Staedte_Noricum2 (cat integer, cat_ integer, cat_ integer,
dbl_1 double precision, dbl_2 double precision, str_1 varchar ( 80 ),
str_2 varchar ( 80 ), str_3 varchar ( 80 ), str_4 varchar ( 80 ), str_6
varchar ( 80 ), int_1 integer)'
So: What can I do to import this Shape-file correctly?
Thanks a lot and have a lot of fun!
Martin
On Fri, Jan 23, 2009 at 11:38 PM, Martin Schweizer
<schweizermartin@students.unibe.ch> wrote:
Hi.
you have basically two options:
- either remove the superfluous cat_ column in the DBF file (Openoffice can
  do that, see
   http://grass.osgeo.org/wiki/Openoffice.org_with_SQL_Databases#DBF_files_.28OpenOffice.org_2.x.29
- or use the cnames option of v.in.ogr to assign new column names on the fly
  http://grass.osgeo.org/gdp/html_grass64/v.in.ogr.html
