Hello,
I’m a user of GRASS7 in UBUNTU 12.04.
I tried to import a PLY File to a GRASS vector points cloud - “cat2.ply”.
v.in.ply input=/home/xxxx/cat2.ply output=cat2xyz
Load:
ply
format ascii 1.0
comment GRASS GIS generated
element vertex 8139
property float x
property float y
property float z
element face 0
property list uchar int vertex_indices
end_header
-96808.46704 -99911.92501 140.613663
-96808.25806 -99912.06045 140.449142
-96597.86902 -99913.83076 146.655823
-96599.28461 -99913.11427 146.4449
-96599.08022 -99913.21988 146.298218
FIRST PROBLEM in results: Only appears the column “Cat” in the table attributes of cat2xyz. But, within the GRASS6.4.2 this action writing the columns x,y,z.
So, I repeat this action with the following statement : v.in.ply input=/home/xxxxx/cat2.ply output=cat2xyz_v1 x=4 y=5 z=6
cat2xyz_v1: The four columns cat,x,y,z in results. But, the GRASS vector missed the region parameters…
v.info -g map=cat2xyz_v1@PERMANENT
north=0
south=0
east=0
west=0
top=0.000000
bottom=0.000000
I would like to get a correct file with the x,y,z coordinates. Is there any solution for this?
Thanks a lot.
Best regards,
Carla
On Mon, May 6, 2013 at 1:14 AM, Carla Rebelo <crrebelo@gmail.com> wrote:
Hello,
I'm a user of GRASS7 in UBUNTU 12.04.
I tried to import a PLY File to a GRASS vector points cloud - "cat2.ply".
Load:
ply
format ascii 1.0
element vertex 8139
property float x
property float y
property float z
element face 0
end_header
FIRST PROBLEM in results: Only appears the column "Cat" in the table
columns x,y,z.
If you want the coordinates also in the table, you can upload
coordinates with v.to.db.
v.in.ply for GRASS 7 is designed for large point clouds with the
possibility to have only coordinates, no attribute table (for speed
reasons).
missed the region parameters...
Because of x=4 y=5 z=6. The default x=1 y=2 z=3 should work just fine, i.e. just
Markus M
north=0
south=0
east=0
west=0
top=0.000000
bottom=0.000000
solution for this?
Thanks a lot.
Best regards,
Carla
grass-user mailing list
grass-user@lists.osgeo.org
