I am running v.kernel on a vector layer of points. The points are mostly bunched up in small-ish areas, but when I run v.kernel, the entire background is yellow.
Is it possible to make v.kernel use a transparent (clear) background where it finds no activity, rather than painting everything yellow first?
I suppose that you got the value 0.000000 in those cells.
This is different from NULL, hence it is not "transparent".
This is different from NULL, hence it is not “transparent”.
