Thanks.
I did this:
v.random output=random_vector n=10000
Then I ran this:
v.kernel --verbose input=random_vector output=random_vector_heatmap stddeviation=1
That just made a large yellow square. So I changed stddeviation to 100 and got a yellow square speckled with teal and dark blue pixels after 7 seconds. Then I changed it to 1000, and after 232(!) seconds, I got something that actually resembles a heat map!
It appears the random_vector map is 100000x100000 units, so I can see why 1000 is necessary to get a reasonable map.
I then ran r.info map=random_vector@de_maps and got this (cut down to key data):
Type of Map: vector (level: 2)
Number of points: 10000
Projection: Lambert Conformal Conic
N: 100000
S: -99975.58519242
E: 99987.79259621
W: -99975.58519242
That looks like it’s around 200000x200000 units?
So I ran v.info map=master_grass7@de_maps on my original vector data and got this key data:
Number of points: 2057980
N: 2781558.27080444
S: 422254.4557289
E: 12145354.2426632
W: 767479.81703687
I went back to the Map Display window for this vector and noticed that about all I am interested in is a box bounded by 1269430.31,1210876.00 on the NW side and 1325045.16,1164615.03 on the SE side. Does this mean I should define a region with this as the bounding box, then re-run v.kernel and hope it works on just that region?
Aren
On Tue, Feb 15, 2011 at 12:15 PM, Marcello Gorini <gorini@gmail.com> wrote:
Aren said:
Where is resolution adjusted?
http://grass.fbk.eu/gdp/html_grass64/v.kernel.html doesn’t make that clear.
GRASS works with the region concept. You can adjust any region settings with
the command g.region, like:
g.region res=desired_resolution -p
The -p is for you to see the resulting changes.
Am I supposed to have a pre-made raster layer already that corresponds to
my
vector layer?
No, you probably don’t. I would suggest you play around with v.random to
create some random points and then use v.kernel to make the heat map. Do
that with different number points, stdev and resolutions to get the feel of
it.
Maybe in this way you will understand what is going on with your specific
case.
I really appreciate your advice!
Any time! Sorry not to help you more.
I’m not upset with the list, was just afraid this was too esoteric or
poorly stated.
I think I myself have been a little upset a few times when I did not get any
responses to my querries
that’s why I mentioned, I guess. But I from
Brazil, so either I get upset or I get really happy
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-kernel-how-to-get-useful-results-tp6018010p6028684.html
grass-user mailing list
grass-user@lists.osgeo.org
