I would like to come up with a "hard" expression of point density -
X per sq km - for my points map, and I'm not sure whether v.kernel
would do so.
If by hard you mean no smoothing, extrapolation, etc, just what the data
points say, you might try 'v.out.ascii | r.in.xyz method=n' after setting
up an appropriate grid size with g.region.
maybe a r.neighbors run could smooth things over.
I don't know much about using v.kernel beyond the basics, so no advice
there.
would do so.
The attraction of v.kernel may be expressed in the answer to this question: how
many 10 km grid squares exist in Australia? Stepping through square-by-square
might be slow; so I thought if I could relate the raster values directly to
original points map, it would get where I want faster.
I suppose if I use a non-lat-long location, with resolution at 1m, it's easy to
step a script by 10000 metres each iteration...
Richard
there.
