[GRASS-user] v.label utf8 possible?
Hello Everyone,
I’d like to create a label for a point vector map with point names to be utilized in map composer (ps.map).
Everything works except that I cannot use my UTF8 strings. They are rendered as latin1 as far as I can see.
Using d.vect strings are displayed correctly:
d.vect --quiet map=places@Duna where=“type=‘village’ OR type=‘town’” color=none fill_color=red width=1 icon=basic/circle attribute_column=name label_color=black label_size=9 font=LinBiolinum_R encoding=UTF-8
but there is no encoding option in v.label. I’ve found some links to v.label.sa which is not available in my Grass setup nor on the extension list.
Grass version is:
> g.version -bre
GRASS 7.0.4 (2016)
./configure --prefix=/opt/grass --with-freetype-includes=/usr/include/freetype2 --with-wxwidgets=/usr/bin/wx-config --with-readline --with-pthread --with-netcdf --with-liblas --with-blas --with-lapack --with-geos --with-nls --with-geos --with-postgres
libgis Revision: 67364
libgis Date: 2015-12-24 16:07:44 +0100 (Thu, 24 Dec 2015)
PROJ.4: 4.9.2
GDAL/OGR: 2.1.0
GEOS: 3.5.0
SQLite: 3.13.0
Is there a chance to create it at all? UTF-8 is essential and some characters I need to print are not available in latin1.
thanks
Robert
On Fri, Jun 24, 2016 at 5:10 PM, Robert Kuszinger <kuszinger@giscom.hu> wrote:
Hello Everyone,
I'd like to create a label for a point vector map with point names to be
d.vect --quiet map=places@Duna where="type='village' OR type='town'"
AFAIK there is no encoding support available in v.labels at time.
Please open an enhancement ticket for this at
https://trac.osgeo.org/grass/newticket
(requires to register first at OSGeo, see there).
I've found some links to
list.
Unfortunately v.label.sa is not compliant with GRASS GIS 7, see
https://trac.osgeo.org/grass/ticket/1942
Fully agreed! Let's follow up via ticket on this.
Markus Neteler
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
Markus,
thanks for the notes. Finally I realized that in an UTF-8 environment what v.label does is ok, its generated files (pure text with pre-calculated placements) are identical to system codepage.
ps.map itself is the component which is limited to latin1.
Actually I haven’t stopped at this problem but started to make an alternative script for myself. In the near future I may have to create maps with khmer text on it.
As a workaround I’ve created a script and discovered that I could simulate the work done by ps.map with some handmade calculations.
The result is not worse (visually in terms of generated code) than my beloved ps.map definition files. I have full control on display, raster, vector and other map gadgets (north, scalebar, etc). I use GRASS_RENDER_* variables, and all d.* commands. Cairo driver with BMP output is very fast. I put each map “layer” into a different BMP files with identicatal resolutions.
Merging (stacking, layering, flattening or whatever you call it) and opacity are the only steps I need to use external command for which is imagemagick.
The resolution is currently a given dpi (300-600) bitmap but I’d like to test the toolchain with svg output as well to keep vectors for best print process.
Anyway, an oversampled bitmap (600 dpi for 300 dpi target) is usually enough so I’m ready for my own purposes.
I’m not too familiar with postcript but I’m also interested if it could be enhanced anyway to work with opentype/ttf unicode fonts and glyphs.
Thanks again
Robert
list.
Fully agreed! Let’s follow up via ticket on this.
Markus Neteler
On Sun, Jun 26, 2016 at 7:38 AM, Robert Kuszinger <kuszinger@giscom.hu> wrote:
Markus,
Actually I haven't stopped at this problem but started to make an
As a workaround I've created a script and discovered that I could simulate
I put each map "layer" into a different BMP files with identicatal
resolutions.
The resolution is currently a given dpi (300-600) bitmap but I'd like to
process.
so I'm ready for my own purposes.
I'm not too familiar with postcript but I'm also interested if it could be
Thanks again
Robert
See related ticket:
https://trac.osgeo.org/grass/ticket/1349
> list.
Markus Neteler
grass-user mailing list
grass-user@lists.osgeo.org
resolutions.
This sounds good. Perhaps you can share your work at some point. It would
be a good contribution to the discussion about the future of ps.map and d.
commands.
process.
Please see:
https://trac.osgeo.org/grass/ticket/3033
Vaclav
but there is no encoding option in v.label. I've found some links to
list.
Grass version is:
AIUI, v.label simply sets the labels as byte strings. Their
interpretation is determined by the program which actually renders the
labels, either by an explicit call to D_encoding(), or from the
environment variable GRASS_ENCODING, or from the font's default
encoding from the fontcap file.
UTF-8 text should work with d.vect and d.labels if you use a FreeType
font (but not for a stroke font, which only provide glyphs for the
ASCII range). I wouldn't expect it to work with anything which
generates PostScript.
Glynn,
thanks for the answer.
“I wouldn’t expect it to work with anything which
generates PostScript.”
I also tested it not only with ps.map but also cairo ps output and ps driver.
ps.map and ps driver fails with utf-8 vector using Biolinum font.
Ghostscript drops the an error on the resulting ps (see e-mail end)
Good news:
Cairo ps output generates even utf-8 d.vect correctly (with rasterized font glyphs), but ignores
export GRASS_RENDER_PS_HEADER=FALSE
export GRASS_RENDER_PS_TRAILER=FALSE
settings. Well, this is understandable since these are PS driver options. A beautiful combination would be to use the cairo PS output with the options above… I know, it is something cairo internal…
thanks again
Robert
--------------------------------------gs all.ps
GPL Ghostscript 9.19 (2016-03-23)
Copyright (C) 2016 Artifex Software, Inc. All rights reserved.
This software comes with NO WARRANTY: see the file PUBLIC for details.
Error: /rangecheck in --imagemask–
Operand stack:
17354512 0 true --nostringval-- --nostringval–
Execution stack:
%interp_exit .runexec2 --nostringval-- --nostringval-- --nostringval-- 2 %stopped_push --nostringval-- --nostringval-- --nostringval-- false 1 %stopped_push 1983 1 3 %oparray_pop 1982 1 3 %oparray_pop 1966 1 3 %oparray_pop 1852 1 3 %oparray_pop --nostringval-- %errorexec_pop .runexec2 --nostringval-- --nostringval-- --nostringval-- 2 %stopped_push --nostringval-- --nostringval-- 1880 5 3 %oparray_pop
Dictionary stack:
–dict:1200/1684(ro)(G)-- --dict:0/20(G)-- --dict:103/200(L)–
Current allocation mode is local
Last OS error: No such file or directory
Current file position is 10807894
GPL Ghostscript 9.19: Unrecoverable error, exit code 1
2016-06-28 0:06 GMT+02:00 Glynn Clements <glynn@gclements.plus.com>:
list.
Grass version is:
environment variable GRASS_ENCODING, or from the font’s default
ASCII range). I wouldn’t expect it to work with anything which
Dear Vaclav,
thanks I’read the whole discussion (ticket 3033). This is very similar to my problem so I added a note.
Yes, I’ll publish what I achieve once it is mature enough for public use.
QUESTION: Is Python a must or could I live on bash/grep and other NX tools? Now it is in bash. I don’t really know python. Well not even bash but at least I have some practice with that. (Normally I work in Smalltalk but that won’t help here :slight_smile: )
thanks
Robert
2016-06-27 18:50 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
This sounds good. Perhaps you can share your work at some point. It would be a good contribution to the discussion about the future of ps.map and d. commands.
Please see:
Vaclav
On Tue, Jun 28, 2016 at 3:16 PM, Robert Kuszinger <kuszinger@giscom.hu>
wrote:
QUESTION: Is Python a must or could I live on bash/grep and other *N*X
tools? Now it is in bash. I don't really know python. Well not even bash
It depends what is the end goal. If the goal is to supply other users with
starting point for their scripts, then Bash is fine. Same applies if the
goal is to provide developers with ideas about what can be developed.
However, if you would like to create a ready-to-use tool which can be
published in GRASS GIS Addons, distributed to users on various operating
systems, and maintained in the long term by various people, then Python is
a better a basically a necessary choice. I think that the Addons option has
additional advantages; one being creation of a better interface on the way.
(Normally I work in Smalltalk but that won't help here :slight_smile: )
In that case, Bash is better :slight_smile:
