I am continuing to try and use Grass to process my LiDAR data. However,
having completed v.lidar.edgedetect successfully I am unable to complete
v.lidar.growing
firstly, just to check, the 'first' parameter is the raw dataset? If not
how do I create the first return dataset?
Secondly, if I run the following:
v.lidar.growing input=alrf_subs_edge@lonsdale output=alrf_subs_grow
first=alrf_subs_raw tj=0.2 td=0.6
All I get is a dbmi:Protocol error, It was impossible to open this
table!
I have seen someone else had this problem on the list in the past but no
definitive solution seemed to occur.
Jack
If this helps:
Tried this on Ubuntu 8.10 using both GRASS 6.3 and 6.4 svn
v.lidar.growing
table!
Jack
On Wed, Apr 22, 2009 at 11:09 PM, Jack Lonsdale <lonsdale@unbc.ca> wrote:
If this helps:
ok - if also in 6.4 present then the "already fixed" argument isn't valid
v.lidar.growing
To my knowledge, no.
AFAIK it is the *last* return which is input to v.lidar.growing.
If not how do I create the first return dataset?
You can use v.extract to separate a mixed map into the different
returns (eg based on an attribute identifying the pulse).
table!
Please send the precise error message.
But it may be that the (if so) previous error of using the wrong input
isn't ideally trapped.
In our book we have successfully used the modules to produce
http://www.grassbook.org/gallery/chapters/s070302f010_cutplanes.jpg
so it worked for us.
Just to clarify: by 'first' I mean the first pulse vector map. On the
help page the usage example only states you need an input and an ouput
vector, but upon trying this the software insists on the input of a
'first=' parameter
I don't know how I could manage this, the only inputs I have are the
x,y,z and intensity?
>> table!
The precise error message is as above 'dbmi:Protocol error, It was impossible to open this table'
Thanks for the help so far though
'first=' parameter
Ah, you are right. Wrong in the manual, fixed now.
Uhm, then I don't know - you have no indication at all about the
pulses order?
>> table!
Perfect, so I could find it: it fails on opening the
table associated to the input vector map. I.e., the output of
v.lidar.edgedetection.
You could run v.lidar.edgedetection without troubles?
The map alrf_subs_edge was created by v.lidar.edgedetection, right?
please
v.info -c alrf_subs_edge
v.info -h alrf_subs_edge
Correction (what luck that is it open source and I can see what
happens in the code authored by someone else!):
v.lidar.edgedetection creates a table "%s_edge_Interpolation", so
in your case
alrf_subs_edge_edge_Interpolation
please instead:
db.describe -c alrf_subs_edge_edge_Interpolation
v.lidar.growing expects here the columns Interp,ID according to the source
code. Otherwise fails as you have seen.
in your case
Yes, no problems here
please instead:
Seems that those exist: db.describe yields the following:
ncols: 2
nrows: 3268897
Column 1: ID:INTEGER:11
Column 2: Interp:DOUBLE PRECISION:20
Jack
ok good.
please instead:
ncols: 2
nrows: 3268897
ok, and check for content:
db.select alrf_subs_edge_edge_Interpolation | head -n 20
Do you use DBF? If not too fat could you package the location with
*relevant* files and make it available to me?
And/or otherwise, make a test with the SQLite DBMI engine?
ok good.
>> please instead:
> ncols: 2
> nrows: 3268897
ID|Interp
1|667.828431
2|668.15324
3|667.76812
4|667.544762
5|667.436508
6|671.106558
7|670.506428
8|670.393883
9|669.995136
10|668.356896
11|668.00097
12|667.822109
13|667.750172
14|667.990251
15|668.405321
16|668.22414
17|668.850224
18|669.299805
19|669.426165
Sorry, I don't know how to do either of those things. Is there an easy
way to do them?
Jack
ID|Interp
1|667.828431
2|668.15324
apparently also fine (at least, columns and data are there).
way to do them?
First we need to know what you use:
db.connect -p
The db.connect manual page also shows how to switch to the
SQLite backend: ideally done in a new mapset. Then add the
previous mapset to the search path with g.mapsets and
repeat there the v.lidar.* commands the in new mapset.
Otherwise I would need the reduced location to look at the
problem. No idea so far why it fails for you.
db.connect -p
OK, So changed to the SQLite backend and managed to run the
v.lidar.edgedetection (although took much longer to process - all day
yesterday) Now when I run v.lidar.growing I get the following
error:DBMI-SQLite driver error:
Error in sqlite3_prepare():SELECT Interp,ID FROM
alrf_subs_edge@sqlite_edge_Interpolation
near "@sqlite_edge_Interpolation": syntax error
It was impossible to open table
What is the best way to compress & send the location?
Thanks once again,
Jack
v.lidar.growing
table!
ha! I guess I found the error.
Please try again *without* specifying the mapset (@lonsdale). If it is
not in the path, use g.mapsets (-s for GUI) to add it.
Runs, right?
The bug is here:
sprintf(buf, "SELECT Interp,ID FROM %s_edge_Interpolation",
in_opt->answer);
db_append_string(&sql, buf);
in_opt->answer contains (in your case) the @mapset part which causes
the DBMI engine to crash. So that should be easy to fix in the module.
@devs: how to strip off the mapset part of a name? Don't remember...
> v.lidar.growing
> table!
Runs, right?
The bug is here:
in_opt->answer);
Brilliant! Works now. Thanks so much,
Jack
