I am trying to understand if GRASS fits me with its v.lrs module and how can I use it
I work as a marine surveyor mainly in the offshore oil & gas industry, occasionly cable & environmental as well.
In this environment, everything is referenced to a (p)line and its offsets.
Offset here are usually meters off a line, + or - outside a line (depending on bearing), which is a different referencing method than the one used in v.lrs, correct?
I.e.
On the page, there are two articles listed which may be of interest,
v.lrs, correct?
In GRASS, an offset is the distance from a milepost along the line.
I work as a marine surveyor mainly in the offshore oil& gas industry,
occasionly cable& environmental as well.
v.lrs, correct?
