[GRASS-user] v.net.iso problem or bug?
Dear grass users
I have a strange problem using v.net.iso
I'm doing an analysis on a river network in a very easy system ( I have
one main channel and two tributaries) in order to calculate distances
from outlet.
i'm running:
v.net.iso --overwrite input=streams_net output=myriver type=line
nlayer=2 ccats=1 costs=100,500,5000
but i have this error:
*** glibc detected *** v.net.iso: realloc(): invalid next size:
0x09c147b8 ***
======= Backtrace: =========
/lib/libc.so.6(+0x6c501)[0x17d501]
/lib/libc.so.6(+0x71c6d)[0x182c6d]
and so on
few months ago an other user have the same problem but it seems he
didn't go to a solution.
If I change the outlet point sometimes could happens v.net.iso work!
So sometimes it works sometimes not...
Is this a bug?
Thanks
Pierluigi
Hello,
first - GRASS version, OS, Arch?
second - have tested with GRASS 7?
third - if dataset is small, TGZ it and drop somewhere for testing
(opening an issue in trac would also be fine).
I have dataset that fails to work with salesman in 6.4.1. I had no
time to make tests with 6.5 and 7. Issue is different - it reports
some nodes to be unreachable after extensive v.clean and v.digit
cleanup. Migh be interesting to collect sample data that causes
v.net.* to fail to try isolate root cause(s) of such failures.
Maris.
2011/4/8, Pierluigi De Rosa <pierluigi.derosa@gfosservices.it>:
Dear grass users
from outlet.
i'm running:
0x09c147b8 ***
and so on
Is this a bug?
Thanks
Pierluigi
grass-user mailing list
grass-user@lists.osgeo.org
Hello,
my GRASS version is GRASS 6.4.0 (2010) (from launchpad repo) on Ubuntu
10.10
At this address http://dl.dropbox.com/u/362123/testing_location.tar.gz
you can download my testing location.
Inside the mapset you have only one vector line outputted from v.net
Try to run this command:
nlayer=2 ccats=1 costs=100,300,2000
I have this error:
Generating isolines...
*** glibc detected *** v.net.iso: malloc(): memory corruption:
0x092cc3e8 ***
Thanks
Pierluigi
Il giorno ven, 08/04/2011 alle 16.34 +0300, Maris Nartiss ha scritto:
Hello,
Maris.
> Dear grass users
> from outlet.
> i'm running:
> 0x09c147b8 ***
> and so on
> Is this a bug?
> Thanks
> Pierluigi
