[GRASS-user] v.net.iso - segmentation fault error
Dear all,
I am unable to use v.net.iso because of a "segmentation fault" error. I
have a script that used to work correctly in GRASS 6.4 (32 bit) but
produces this error after I switched to GRASS 7.0.4 (64 bit).
If I try to follow both examples shown in https://grass.osgeo.org/grass
70/manuals/v.net.iso.html (using the Spearfish dataset for GRASS 7) the
same error appears:
Building graph...
Registering arcs...
Segmentation fault
What I am missing?
Thanks in advance.
Greetings.
Eduardo Corbelle
Dr. Eduardo Corbelle Rico
Land laboratory (LaboraTe)
Department of Agricultural and Forest Engineering
Universidade de Santiago de Compostela
e-mail: eduardo.corbelle@usc.es
Tel: +34 982 823 324
Fax: +34 982 285 926
Web: http://laborate.usc.es
http://masterterra.usc.es
http://github.com/eduardocorbelle
On Thu, Oct 13, 2016 at 9:55 AM, Eduardo Corbelle Rico
<eduardo.corbelle@gmx.net> wrote:
Dear all,
same error appears:
Building graph...
Registering arcs...
Segmentation fault
The segmentation fault must happen in the vector libraries. I tested
on Linux and can not reproduce the segmentation fault. Valgrind also
does not show anything that could cause a segmentation fault. Can you
provide a gdb backtrace?
Markus M
What I am missing?
Thanks in advance.
Greetings.
Eduardo Corbelle
grass-user mailing list
grass-user@lists.osgeo.org
O Mér, 26-10-2016 ás 23:18 +0200, Markus Metz escribiu:
> Dear all,
> error. I
> but
> rass
> the
> same error appears:
> > Building graph...
> > Registering arcs...
> > Segmentation fault
Markus M
Thank you Markus,
My system is debian Stretch, and the following lines describe my
attempt at generating a gdb backtrace. Please let me know if I should
do otherwise.
GRASS 7.0.5 (spearfish60_grass7):~ > gdb `which v.net.iso`
GNU gdb (Debian 7.11.1-2) 7.11.1
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl
.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show
copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/&gt;\.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/&gt;\.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/lib/grass70/bin/v.net.iso...(no debugging
symbols found)...done.
(gdb) run input=myroads_net output=myroads_net_iso center_cats=1-100000
costs=1000,2000,5000
Starting program: /usr/lib/grass70/bin/v.net.iso input=myroads_net
output=myroads_net_iso center_cats=1-100000 costs=1000,2000,5000
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-
gnu/libthread_db.so.1".
Building graph...
Registering arcs...
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff6c64708 in tavl_probe ()
from /usr/lib/grass70/lib/libgrass_dgl.7.0.5.so
(gdb) bt full
#0 0x00007ffff6c64708 in tavl_probe ()
No symbol table info available.
#1 0x00007ffff6c65717 in dglTreeNodeAdd ()
#2 0x00007ffff6c5aa0c in dgl_add_edge_V1 ()
#3 0x00007ffff6c58a62 in dglAddEdge ()
#4 0x00007ffff7ba1d69 in Vect_net_build_graph ()
from /usr/lib/grass70/lib/libgrass_vector.7.0.5.so
#5 0x0000000000401aa9 in main ()
(gdb) l
1 ../sysdeps/x86_64/dl-procinfo.c: Non hai tal ficheiro ou
directorio.
> What I am missing?
> Thanks in advance.
> Greetings.
> Eduardo Corbelle
On Thu, Oct 27, 2016 at 11:16 AM, Eduardo Corbelle Rico
> Dear all,
> error. I
> but
> rass
> the
> same error appears:
> > Building graph...
> > Registering arcs...
> > Segmentation fault
Markus M
Thank you Markus,
do otherwise.
So far so good. The module crashes in a library function that comes
from libavl without modifications, but I can still not see why it
could cause a segmentation fault. Can you recompile with the compiler
debugging option -g? gdb will then be able to provide more
information:
make distclean
CFLAGS="-g" ./configure <configure options>
make
optionally make install
Then start GRASS and use gdb for v.net.iso as before.
Markus M
.html>
copying"
Building graph...
Registering arcs...
(gdb) bt full
(gdb) l
directorio.
> What I am missing?
> Thanks in advance.
> Greetings.
> Eduardo Corbelle
O Xov, 27-10-2016 ás 14:56 +0200, Markus Metz escribiu:
> > > Dear all,
> > > error. I
> > > bit)
> > > but
> > > rg/g
> > > rass
> > > GRASS 7)
> > > the
> > > same error appears:
> > > > Building graph...
> > > > Registering arcs...
> > > > Segmentation fault
> > tested
> > also
> > you
> > Markus M
> Thank you Markus,
> should
> do otherwise.
information:
make distclean
make
Markus M
Thank you, I'll try. Grass was installed in my system using pre-
compiled packages (via apt-get)... Forgive me if this is a silly
question: from which folder am I supposed to execute the commands? (or
should I download the source files and start all over?)
> /gpl
> .html>
> copying"
> 100000
> Building graph...
> Registering arcs...
> (gdb) bt full
> (gdb) l
> directorio.
> > > What I am missing?
> > > Thanks in advance.
> > > Greetings.
> > > Eduardo Corbelle
> > > _______________________________________________
On Fri, Oct 28, 2016 at 10:11 AM, Eduardo Corbelle Rico
Please check the guide here:
https://grass.osgeo.org/development/compiling-grass-gis/
If it is not sufficient, let us know and we can improve it!
cheers
markusN
> > > Dear all,
> > > error. I
> > > bit)
> > > but
> > > rg/g
> > > rass
> > > GRASS 7)
> > > the
> > > same error appears:
> > > > Building graph...
> > > > Registering arcs...
> > > > Segmentation fault
> > tested
> > also
> > you
> > Markus M
> Thank you Markus,
> should
> do otherwise.
information:
make distclean
make
Markus M
Dear Markus,
Following those instructions does not seem to have changed the
resulting backtrace info (copied below). Maybe I missed something along
the way?
make distclean
CFLAGS="-g" ./configure --with-freetype-includes=/usr/include/freetype2
make
sudo make install
GNU gdb (Debian 7.11.1-2+b1) 7.11.1
.html>
copying"
Building graph...
Registering arcs...
(gdb) bt full
#5 0x0000555555555b08 in main ()
(gdb) l
directorio.
> > > What I am missing?
> > > Thanks in advance.
> > > Greetings.
> > > Eduardo Corbelle
On Wed, Nov 16, 2016 at 11:44 AM, Eduardo Corbelle Rico <eduardo.corbelle@gmx.net> wrote:
Dear all,
I am unable to use v.net.iso because of a “segmentation fault”
error. I
bit)
but
rg/g
rass
GRASS 7)
the
same error appears:
Building graph…
Registering arcs…
Segmentation fault
tested
also
you
Markus M
Thank you Markus,
should
do otherwise.
information:
make distclean
CFLAGS=“-g” ./configure
make
Markus M
Dear Markus,
the way?
make distclean
CFLAGS=“-g” ./configure --with-freetype-includes=/usr/include/freetype2
make
sudo make install
GRASS 7.0.5 (spearfish60_grass7):~ > gdb which v.net.iso
.html>
There is NO WARRANTY, to the extent permitted by law. Type “show
copying”
and “show warranty” for details.
This GDB was configured as “x86_64-linux-gnu”.
Type “show configuration” for configuration details.
<http://www.gnu.org/software/gdb/bugs/>.
<http://www.gnu.org/software/gdb/documentation/>.
For help, type “help”.
Type “apropos word” to search for commands related to “word”…
This is the problem:
Reading symbols from /usr/lib/grass70/bin/v.net.iso…(no debugging
symbols found)…done.
It should be
Reading symbols from /usr/lib/grass70/bin/v.net.iso…done.
For testing purposes I introduced a bug in my local copy to trigger a segmentation fault. The backtrace shows:
(gdb) bt
#0 tavl_probe (tree=tree@entry=0x827d30, item=item@entry=0x82fb20) at tavl.c:131
#1 0x00007ffff6c3d3e7 in dglTreeNodeAdd (pavl=0x827d30, nKey=nKey@entry=1) at tree.c:73
#2 0x00007ffff6c32d17 in dgl_add_edge_V1 (pgraph=0x7fffffffccf8, nHead=, nTail=, nCost=1231014,
nEdge=1, pvHeadAttr=pvHeadAttr@entry=0x0, pvTailAttr=0x0, pvEdgeAttr=0x0, nFlags=0) at edgemgmt-template.c:59
#3 0x00007ffff6c30ea2 in dglAddEdge (pGraph=pGraph@entry=0x7fffffffccf8, nHead=, nTail=,
nCost=, nEdge=nEdge@entry=1) at graph.c:624
#4 0x00007ffff7bb5d09 in Vect_net_build_graph (Map=Map@entry=0x7fffffffc920, ltype=ltype@entry=6, afield=afield@entry=1,
nfield=nfield@entry=2, afcol=0x0, abcol=0x0, ncol=0x0, geo=0, version=1) at net_build.c:918
#5 0x00000000004029e1 in main (argc=, argv=) at main.c:224
Note that file and line are given where the segfault occured.
Is this something Debian specific that debugging symbols must be explicitly activated? Are you using GCC or another compiler?
Alternatively, you can also try valgrind:
CMD=“v.net.iso input=myroads_net output=myroads_net_iso center_cats=1-100000 costs=1000,2000,5000 --o”
valgrind --tool=memcheck --log-file=v.net.iso.vg.log $CMD
Markus M
Using host libthread_db library “/lib/x86_64-linux-
gnu/libthread_db.so.1”.
Building graph…
Registering arcs…
(gdb) bt full
(gdb) l
1 …/sysdeps/x86_64/dl-procinfo.c: Non hai tal ficheiro ou
directorio.
What I am missing?
Thanks in advance.
Greetings.
Eduardo Corbelle
O Mér, 16-11-2016 ás 15:22 +0100, Markus Metz escribiu:
> > > > > Dear all,
fault"
> > > > > error. I
> > > > > bit)
> > > > > but
bit).
eo.o
> > > > > rg/g
> > > > > rass
> > > > > GRASS 7)
> > > > > the
> > > > > same error appears:
> > > > > > Building graph...
> > > > > > Registering arcs...
> > > > > > Segmentation fault
> > > > tested
Valgrind
> > > > also
Can
> > > > you
> > > > Markus M
> > > Thank you Markus,
my
> > > should
> > > do otherwise.
comes
compiler
> > information:
> > make distclean
> > make
> > Markus M
> Dear Markus,
along
> the way?
CMD="v.net.iso input=myroads_net output=myroads_net_iso
center_cats=1-100000 costs=1000,2000,5000 --o"
Markus M
You were right: it was my fault not having grass-core-dbgsym and grass-
dev-dbgsym packages installed. I copied below the results of the
debugging commands:
.html>
copying"
Reading symbols from /usr/lib/grass70/bin/v.net.iso...Reading symbols
from /usr/lib/debug/.build-
id/5a/060fc6c3da41153d82601e3fa37ba6d88e9c6c.debug...done.
done.
Building graph...
Registering arcs...
tavl_probe (tree=tree@entry=0x55555599b6c0, item=item@entry=0x55555599f
7b0)
at tavl.c:146
146 tavl.c: Non hai tal ficheiro ou directorio.
(gdb) bt full
#0 tavl_probe (tree=tree@entry=0x55555599b6c0, item=item@entry=0x55555
599f7b0)
at tavl.c:146
y = 0x0
z = 0x55555599b6c0
p = 0x0
q = <optimized out>
n = 0x55555599f7d0
w = <optimized out>
dir = <optimized out>
da =
"\023\000\000\000\000\000\000\000\000\vb\367\377\177\000\000\300\266\23
1UUU\000\000\030\000\000\000\000\000\000"
k = 0
__PRETTY_FUNCTION__ = "tavl_probe"
#1 0x00007ffff6c65717 in dglTreeNodeAdd (pavl=0x55555599b6c0,
pnode = 0x55555599f7b0
ppvret = <optimized out>
#2 0x00007ffff6c5aa0c in dgl_add_edge_V1 (pgraph=0x7fffffffd078,
nHead=<optimized out>, nTail=<optimized out>, nCost=1231014,
nEdge=1,
nFlags=0)
pHead = <optimized out>
pTail = <optimized out>
    pEdgeset = &lt;optimized out&gt;
    pEdge = &lt;optimized out&gt;
    pHeadNodeItem = &lt;optimized out&gt;
    pTailNodeItem = &lt;optimized out&gt;
#3 0x00007ffff6c58a62 in dglAddEdge (pGraph=pGraph@entry=0x7fffffffd07
8,
nHead=<optimized out>, nTail=<optimized out>, nCost=<optimized
out>,
nRet = <optimized out>
#4 0x00007ffff7ba1d69 in Vect_net_build_graph (Map=0x7fffffffcca0,
ltype=<optimized out>, afield=1, nfield=2, afcol=0x0, abcol=0x0,
ncol=0x0,
geo=0, version=1) at net.c:303
i = 1
j = <optimized out>
from = 1
to = 2
line = <optimized out>
nlines = <optimized out>
nnodes = <optimized out>
type = <optimized out>
cat = 48
skipped = 0
cfound = <optimized out>
    dofw = &lt;optimized out&gt;
    dobw = 1
    Points = &lt;optimized out&gt;
    Cats = 0x5555557602f0
    dcost = 1231\.0148500818718
    bdcost = 1231\.0148500818718
    ll = &lt;optimized out&gt;
    cost = 1231014
    bcost = 0
    gr = 0x7fffffffd078
    dgl\_cost = 0
    opaqueset = \{360000, 0 &lt;repeats 15 times&gt;\}
    Fi = &lt;optimized out&gt;
    driver = &lt;optimized out&gt;
    handle = \{dbName = \{string = 0x0, nalloc = 0\}, dbSchema = \{
        string = 0x0, nalloc = 0\}\}
    stmt = \{string = 0x0, nalloc = 0\}
    Column = 0x0
    fvarr = \{n\_values = \-13424, alloc = 32767, ctype = \-148152984,
      value = 0x53455f0043\}
    bvarr = \{n\_values = 0, alloc = 0, ctype = \-148153640,
      value = 0x415353454d5f434c\}
    fctype = &lt;optimized out&gt;
    bctype = &lt;optimized out&gt;
    nrec = &lt;optimized out&gt;
#5 0x0000555555555b08 in main (argc=<optimized out>, argv=<optimized
out>)
at main.c:190
i = <optimized out>
centre = <optimized out>
centre1 = <optimized out>
centre2 = <optimized out>
type = 6
ltype = <optimized out>
geo = 0
cat = 32767
node = <optimized out>
node1 = -13264
node2 = 32767
cost = -nan(0xfefbd28e20000)
e1cost = 6.9533475197415044e-310
e2cost = 6.9533490679313337e-310
n1cost = 6.9531436082559572e-310
    n2cost = 6\.953349164098692e\-310
    s1cost = &lt;optimized out&gt;
    s2cost = &lt;optimized out&gt;
    l1 = &lt;optimized out&gt;
    map = 0x7ffff7b67888 &lt;state\+136&gt;
    output = 0x555555790a10
    afield\_opt = &lt;optimized out&gt;
    nfield\_opt = &lt;optimized out&gt;
    afcol = 0x555555790cd0
    abcol = 0x555555790d70
    ncol = 0x555555790e10
    type\_opt = &lt;optimized out&gt;
    term\_opt = &lt;optimized out&gt;
    cost\_opt = &lt;optimized out&gt;
    geo\_f = 0x7ffff7b67858 &lt;state\+88&gt;
    module = &lt;optimized out&gt;
    Map = \{format = 0, temporary = 0, dblnk = 0x5555557919b0, plus
version = {topo = {major = 5, minor = 1, back_major = 5,
back_minor = 1}, spidx = {major = 5, minor = 1,
back_major = 5, back_minor = 1}, cidx = {major = 5,
minor = 0,
back_major = 5, back_minor = 0}}, with_z = 0,
spidx_with_z = 0, off_t_size = 4, head_size = 142,
        spidx\_head\_size = 113, cidx\_head\_size = 9, release\_support
= 0,
port = {byte_order = 0, off_t_size = 0,
dbl_cnvrt = "\000\001\002\003\004\005\006\a",
flt_cnvrt = "\000\001\002\003", lng_cnvrt =
"\000\001\002\003",
int_cnvrt = "\000\001\002\003", shrt_cnvrt = "\000\001",
off_t_cnvrt = "\000\001\002\003\004\005\006\a", dbl_quick
= 1,
flt_quick = 1, lng_quick = 1, int_quick = 1, shrt_quick =
1,
off_t_quick = 1}, spidx_port = {byte_order = 0,
off_t_size = 4,
"\000\001\002\003",
= 1,
1,
off_t_quick = 1}, cidx_port = {byte_order = 0, off_t_size
= 0,
"\000\001\002\003",
= 1,
1,
off_t_quick = 1}, mode = 0, built = 4, box = {
N = 4928063.3980146097, S = 4914006.3378370199,
E = 609527.21021496004, W = 589434.85646865005, T = 0, B
= 0},
Node = 0x555555797d50, Line = 0x5555557aa880,
        Area = 0x5555557b9150, Isle = 0x5555557b9170, n\_plines =
1,
n_llines = 827, n_blines = 0, n_clines = 0, n_flines = 0,
n_klines = 0, n_vfaces = 0, n_hfaces = 0, n_nodes = 678,
n_edges = 0, n_lines = 828, n_areas = 0, n_isles = 0,
n_faces = 0,
n_volumes = 0, n_holes = 0, alloc_nodes = 678, alloc_edges
= 0,
alloc_lines = 828, alloc_areas = 0, alloc_isles = 0,
alloc_faces = 0, alloc_volumes = 0, alloc_holes = 0,
Node_offset = 142, Edge_offset = 0, Line_offset = 26934,
Area_offset = 37690, Isle_offset = 37690, Volume_offset =
0,
Hole_offset = 0, Spidx_built = 1, Spidx_new = 0, Spidx_file
= 1,
spidx_fp = {file = 0x555555796d40, start = 0x0, current =
0x0,
end = 0x0, size = 0, alloc = 0, loaded = 0},
Node_spidx_offset = 61041, Line_spidx_offset = 131013,
Area_spidx_offset = 131489, Isle_spidx_offset = 131965,
Face_spidx_offset = 0, Volume_spidx_offset = 0,
Hole_spidx_offset = 0, Node_spidx = 0x555555792880,
Line_spidx = 0x55555582e8a0, Area_spidx = 0x5555558a7d80,
Isle_spidx = 0x555555921260, Face_spidx = 0x0, Volume_spidx
= 0x0,
Hole_spidx = 0x0, update_cidx = 0, n_cidx = 2, a_cidx = 5,
cidx = 0x555555795d70, cidx_up_to_date = 1, coor_size =
101723,
coor_mtime = 0, uplist = {do_uplist = 0, uplines = 0x0,
uplines_offset = 0x0, alloc_uplines = 0, n_uplines = 0,
upnodes = 0x0, alloc_upnodes = 0, n_upnodes = 0}},
      open = 1428335138, mode = 0, level = 2, head\_only = 0,
      support\_updated = 0, name = 0x555555760170 &quot;myroads\_net&quot;,
      mapset = 0x555555760470 &quot;user1&quot;,
      location = 0x555555760530 &quot;spearfish60\_grass7&quot;,
      gisdbase = 0x5555557605f0 &quot;/home/eduardo/GRASSDATA&quot;,
next_line = 1,
constraint = {region_flag = 0, box = {N = 0, S = 0, E = 0, W
= 0,
T = 0, B = 0}, type_flag = 0, type = 0, field_flag = 0,
field = 0}, proj = 0, hist_fp = 0x55555599f010, dgraph = {
line_type = 6, graph_s = {iErrno = 0, Version = 1 '\001',
Endian = 1 '\001', NodeAttrSize = 0, EdgeAttrSize = 0,
aOpaqueSet = {360000, 0 <repeats 15 times>}, cNode = 0,
cHead = 0, cTail = 0, cAlone = 0, cEdge = 0, nnCost = 0,
Flags = 0, nFamily = 0, nOptions = 0,
pNodeTree = 0x55555599b6c0, pEdgeTree = 0x0, pNodeBuffer
= 0x0,
iNodeBuffer = 0, pEdgeBuffer = 0x0, iEdgeBuffer = 0,
edgePrioritizer = {cEdge = 0, iEdge = 0, pEdgePri32Item =
0x0,
pvAVL = 0x0}, nodePrioritizer = {pvAVL = 0x0}}, spCache
nStartNode = 0, NodeHeap = {index = 0, count = 0, block =
0,
pnode = 0x0}, pvVisited = 0x0, pvPredist = 0x0},
edge_fcosts = 0x5555559a0490, edge_bcosts =
0x5555559a1e80,
node_costs = 0x5555559a3870, cost_multip = 1000}, head = {
organization = 0x555555795a50 "US Army Const. Eng. Rsch.
Lab",
date = 0x555555760770 "5/26/90",
        user\_name = 0x555555760850 &quot;youngs&quot;,
        map\_name = 0x555555760910 &quot;Output from Vpatch&quot;,
        source\_date = 0x5555557606b0 &quot;1961&quot;, orig\_scale = 24000,
        comment = 0x555555796d00 &quot;new roads at 1:24000 for
Spearfish database", proj = 1, plani_zone = 13, digit_thresh = 18.288,
coor_version = {
major = 5, minor = 1, back_major = 5, back_minor = 1},
with_z = 0, size = 101723, head_size = 18, port =
{byte_order = 0,
off_t_size = 0, dbl_cnvrt =
"\000\001\002\003",
= 1,
1,
off_t_quick = 1}, last_offset = 18, recycle = 0x0},
dig_fp = {
file = 0x55555599b700, start = 0x0, current = 0x0, end =
0x0,
size = 0, alloc = 0, loaded = 0}, fInfo = {i = 0, ogr = {
driver_name = 0x0, dsn = 0x0, layer_name = 0x0, driver =
0x0,
ds = 0x0, layer = 0x0, dbdriver = 0x0, dsn_options =
0x0,
layer_options = 0x0, cache = {lines = 0x0, lines_types =
0x0,
lines_cats = 0x0, lines_alloc = 0, lines_num = 0,
lines_next = 0, fid = 0, sf_type = SF_GEOMETRY, ctype =
0},
feature_cache = 0x0, offset = {array = 0x0, array_num =
0,
array_alloc = 0}, next_line = 0}, pg = {conninfo =
0x0,
db_name = 0x0, schema_name = 0x0, table_name = 0x0,
          fid\_column = 0x0, geom\_column = 0x0, feature\_type =
SF_GEOMETRY,
coor_dim = 0, srid = 0, dbdriver = 0x0, fi = 0x0,
inTransaction = 0, conn = 0x0, res = 0x0, cursor_name =
0x0,
cursor_fid = 0, next_line = 0, cache = {lines = 0x0,
lines_types = 0x0, lines_cats = 0x0, lines_alloc = 0,
lines_num = 0, lines_next = 0, fid = 0, sf_type =
SF_GEOMETRY,
ctype = 0}, offset = {array = 0x0, array_num = 0,
array_alloc = 0}, topogeom_column = 0x0,
toposchema_name = 0x0, toposchema_id = 0, topo_geo_only =
0}},
site_att = 0x0, n_site_att = 0, n_site_dbl = 0, n_site_str =
0}
Out = {format = -1478492160, temporary = -1,
dblnk = 0xffffefbd28e20000, plus = {version = {topo = {
major = -165154152, minor = 32767, back_major =
-136416591,
back_minor = 32767}, spidx = {major = 1, minor =
32767,
back_major = -134430384, back_minor = 32767}, cidx = {
major = -11776, minor = 32767, back_major = 685899776,
back_minor = -4163}}, with_z = -161323944,
spidx_with_z = 32767, off_t_size = -136417169,
head_size = 140733193388033, spidx_head_size =
140737353923672,
cidx_head_size = 140737488344240, release_support =
685899776,
port = {byte_order = -4163, off_t_size = -161323992,
dbl_cnvrt = "\377\177\000\000op\336", <incomplete
sequence \367>, flt_cnvrt = "\377\177\000", lng_cnvrt =
"\001\000\000",
          int\_cnvrt = &quot;\\377\\177\\000&quot;,
          shrt\_cnvrt = &quot;\\330&quot;, &lt;incomplete sequence \\331&gt;,
          off\_t\_cnvrt = &quot;\\377\\367\\377\\177\\000\\000\\340&quot;, &lt;incomplete
sequence \324>, dbl_quick = 32767, flt_quick = 685899776, lng_quick =
-4163,
int_quick = -141390440, shrt_quick = 32767,
off_t_quick = -136417169}, spidx_port = {byte_order =
32767,
off_t_size = 1,
dbl_cnvrt = "\377\177\000\000\000\265\374", <incomplete
"\020\325\377\377",
int_cnvrt = "\377\177\000", shrt_cnvrt = "\000",
off_t_cnvrt = "\342(\275\357\377\377pb", dbl_quick =
32767,
flt_quick = -136417169, lng_quick = 32767, int_quick =
1,
shrt_quick = 32767, off_t_quick = -134434816}, cidx_port
byte_order = 32767, off_t_size = -10944,
dbl_cnvrt = "\377\177\000\000\000\000\342(",
flt_cnvrt = "\275\357\377\377",
lng_cnvrt = "`b\266", <incomplete sequence \367>,
int_cnvrt = "\377\177\000", shrt_cnvrt = "op",
off_t_cnvrt = "\336\367\377\177\000\000\001", dbl_quick =
32767,
flt_quick = -134420240, lng_quick = 32767, int_quick =
-10896,
shrt_quick = 32767, off_t_quick = 685899776}, mode =
-4163,
built = -136480704, box = {N = 6.9533490679313337e-310,
S = 6.9531436082559572e-310, E = 6.9533491665290997e-
310,
          W = 6\.9533558072990419e\-310, T = \-nan\(0xfefbd28e20000\),
          B = 6\.9533490647914972e\-310\},
        Node = 0x7ffff7de706f &lt;\_dl\_map\_object\_deps\+607&gt;,
        Line = 0x7fff00000001, Area = 0x7ffff7fcdee0,
        Isle = 0x7fffffffd5d0, n\_plines = 685899776, n\_llines =
-4163,
n_blines = -136480736, n_clines = 32767, n_flines =
-136417169,
n_klines = 32767, n_vfaces = 1, n_hfaces = 32767,
n_nodes = -134424112, n_edges = 32767, n_lines = -10752,
n_areas = 32767, n_isles = 685899776, n_faces = -4163,
n_volumes = -136480752, n_holes = 32767, alloc_nodes =
-136417169,
alloc_edges = 32767, alloc_lines = 1, alloc_areas = 32767,
alloc_isles = -134425368, alloc_faces = 32767,
alloc_volumes = -10704, alloc_holes = 32767,
Node_offset = -17879262953472, Edge_offset =
140737351874544,
Line_offset = 140737351938159, Area_offset =
140733193388033,
Isle_offset = 140737353928704, Volume_offset =
140737488344672,
Hole_offset = -17879262953472, Spidx_built = -136480800,
Spidx_new = 32767, Spidx_file = -136417169, spidx_fp = {
file = 0x7fff00000001, start = 0x7ffff7fd0930 "",
current = 0x7fffffffd690 "\001",
end = 0x7ffff7de3114 <check_match+324>
"\205\300\017\205m\377\377\377\351z\377\377\377\017\037\200", size =
140737351874512, alloc = 302,
loaded = -134545704}, Node_spidx_offset =
140736985276032,
        Line\_spidx\_offset = 140736985286208,
        Area\_spidx\_offset = 140737351924051, Isle\_spidx\_offset =
302,
Face_spidx_offset = 140736985286208,
Volume_spidx_offset = 140737353809624,
Hole_spidx_offset = 140737488345016, Node_spidx =
0x7fffffffd7b4,
Line_spidx = 0xffffefbd28e20000, Area_spidx =
0x7fffe203c70d,
Isle_spidx = 0x7fffe203bad0, Face_spidx = 0x7fffffffd7b8,
Volume_spidx = 0x97a26e6c, Hole_spidx = 0x25e89b9,
update_cidx = -503069120, n_cidx = 32767, a_cidx = -10096,
cidx = 0x7fffe2039e80, cidx_up_to_date = -10316,
coor_size = 140737488345216, coor_mtime = 140737353776784,
uplist = {do_uplist = -136433388, uplines = 0xf7dd7780,
uplines_offset = 0x197, alloc_uplines = -134253520,
n_uplines = 32767, upnodes = 0x7ffff728bd90,
alloc_upnodes = -148271048, n_upnodes = 32767}},
open = -136433388, mode = 32767, level = 407, head_only = 0,
support_updated = -136433388, name = 0x7ffff7fcbc58 "",
mapset = 0x83a <error: Cannot access memory at address
0x83a>,
location = 0x7ffff7ff7430 "", gisdbase = 0x7ffff728bd90 "",
next_line = -148271048, constraint = {region_flag =
-136431277,
box = {N = 1.0405022501416652e-320, S =
6.9533484822718954e-310,
E = 6.9533491748297978e-310, W = 6.9533558073381719e-
310,
T = 6.9533558073379743e-310, B = 6.9533490671516982e-
310},
        type\_flag = \-201603917, type = 32767, field\_flag =
-201740488,
field = 32767}, proj = -10056, hist_fp = 0x1c93965e, dgraph
line_type = 7491161, graph_s = {iErrno = -136433388,
Version = 255 '\377', Endian = 127 '\177',
NodeAttrSize = 140737488345488, EdgeAttrSize = 990,
aOpaqueSet = {140737354101808, 140737340030352,
140737340084280,
140737351924051, 990, 140737340084280,
140737354101808,
140737488345416, 140737488345412, 140737351922379,
140737278937163, 140737278684160, 140737488345416,
2822930839,
44108294, 140737340084280}, cNode = 140737488345632,
cHead = 140737340030352, cTail = 140737488345412,
cAlone = 140737488345616, cEdge = 140737353776784, nnCost
= 120,
Flags = 4294957648, nFamily = 7426, nOptions =
4160538376,
pNodeTree = 0x0, pEdgeTree = 0x7ffff383b200,
pNodeBuffer = 0x7ffff7fcca60 " \344\377\367\377\177",
iNodeBuffer = 140737488345776,
pEdgeBuffer = 0x7ffff7fa5fd8 "\256\266\215\363\377\177",
iEdgeBuffer = 0, edgePrioritizer = {cEdge = -136433388,
iEdge = 32767, pEdgePri32Item = 0x7ffff72bb040
<__restore_rt>,
pvAVL = 0xa50}, nodePrioritizer = {pvAVL =
0x7ffff7fcbc58}},
spCache = {nStartNode = 140737286612536, NodeHeap = {
index = 140737286745064, count = 140737351924051,
block = 2640, pnode = 0x7ffff3fbabe8},
          pvVisited = 0x7ffff7fcbc58, pvPredist = 0x7fffffffda58\},
        edge\_fcosts = 0x7fffffffda54,
        edge\_bcosts = 0x7ffff7de32cb &lt;do\_lookup\_x\+347&gt;,
        node\_costs = 0x7ffff387b022, cost\_multip = \-209671024\},
head = {
organization = 0x7fffffffda58 "",
date = 0x4cd4b8c7 <error: Cannot access memory at address
0x4cd4b8c7>, user_name = 0x13352e3 <error: Cannot access memory at
address 0x13352e3>,
map_name = 0x7ffff3fbabe8 "",
source_date = 0x7fffffffdb30 "\270\235\372\363\377\177",
orig_scale = 140737286612536, comment = 0x7fffffffda54 "",
proj = -9440, plani_zone = 32767,
digit_thresh = 6.9533491587714785e-310, coor_version = {
major = 120, minor = 0, back_major = -9320, back_minor =
0},
with_z = -136429983, size = 23, head_size = 0, port = {
byte_order = 1, off_t_size = 0,
dbl_cnvrt = "`\312\374\367\377\177\000",
flt_cnvrt = "\300\333\377\377", lng_cnvrt =
"\377\177\000",
int_cnvrt = "\250_\372", <incomplete sequence \367>,
shrt_cnvrt = "\377\177",
off_t_cnvrt = "\000\000\001\000\000\000\000", dbl_quick =
0,
flt_quick = 0, lng_quick = -9240, int_quick = 32767,
shrt_quick = -136429983, off_t_quick = 32767},
last_offset = 21,
recycle = 0x7ffff7fa5fa8}, dig_fp = {file = 0x1, start =
0x0,
        current = 0x1 &lt;error: Cannot access memory at address
0x1>,
end = 0x7ffff7fcc708 "", size = 0, alloc = 0, loaded = 0},
fInfo = {i = -134428064, ogr = {
driver_name = 0x7fffffffdb30 "\270\235\372\363\377\177",
dsn = 0x100000000 <error: Cannot access memory at address
0x100000000>, layer_name = 0x7ffff7fcc708 "", driver = 0x7fffffffdb20,
ds = 0x7ffff387b022, layer = 0x4cd4b8c7, dbdriver =
0xffffffff,
dsn_options = 0x0, layer_options = 0x7ffff3fa9db8, cache
lines = 0x7ffff7fcbc58, lines_types = 0x0,
lines_cats = 0x28206e6f10000000, lines_alloc =
1952531488,
lines_num = 1396982881, lines_next = 1145315372,
fid = 140737280262720, sf_type = 8, ctype = 0},
feature_cache = 0x1, offset = {array = 0x0, array_num =
-9320,
array_alloc = 32767}, next_line = -136429983}, pg = {
conninfo = 0x17 <error: Cannot access memory at address
0x17>,
db_name = 0x7ffff3d74a60 "\300\024\003\364\377\177",
schema_name = 0x7fffffffdda8 "v\341\377\377\377\177",
table_name = 0x7fffffffddd8 "\350\341\377\377\377\177",
fid_column = 0x7ffff3d38ef0 "pa\227\363\377\177",
geom_column = 0x0, feature_type = SF_MULTILINESTRING,
coor_dim = 0, srid = -136410668, dbdriver = 0x1, fi =
0x0,
inTransaction = -204239120, conn = 0x7ffff3fa9db8,
res = 0x7fffffffdd00,
          cursor\_name = 0x7ffff7df006f
<_dl_runtime_resolve_sse+159> "I\211\303f\017\032\234$\260", cursor_fid
lines_types = 0x0, lines_cats = 0x40, lines_alloc =
1040,
lines_num = 0, lines_next = 64, fid = 1040, sf_type =
1088,
ctype = 0}, offset = {array = 0x10, array_num = 66,
array_alloc = 64},
topogeom_column = 0x2 <error: Cannot access memory at
address 0x2>, toposchema_name = 0x0, toposchema_id = 93, topo_geo_only
= 110}},
119}
catlist = 0x555555791380
Centers = 0x0
acentres = 0
ncentres = 0
Nodes = <optimized out>
Cats = 0x55555575efc0
Points = 0x555555791020
SPoints = 0x555555791350
niso = <optimized out>
aiso = <optimized out>
iso = 0x5555557913b0
npnts1 = <optimized out>
apnts1 = 0
npnts2 = <optimized out>
    apnts2 = 0
    pnts1 = 0x0
    pnts2 = 0x0
    next\_iso = &lt;optimized out&gt;
(gdb) bt full
599f7b0)
at tavl.c:146
y = 0x0
z = 0x55555599b6c0
p = 0x0
q = <optimized out>
n = 0x55555599f7d0
w = <optimized out>
da =
k = 0
nEdge=1,
nFlags=0)
8,
out>,
ncol=0x0,
i = 1
j = <optimized out>
from = 1
to = 2
cat = 48
skipped = 0
    dobw = 1
    cost = 1231014
    bcost = 0
    gr = 0x7fffffffd078
    dgl\_cost = 0
    Column = 0x0
out>)
at main.c:190
i = <optimized out>
type = 6
geo = 0
cat = 32767
node1 = -13264
node2 = 32767
minor = 0,
= 0,
"\000\001\002\003",
= 1,
1,
off_t_size = 4,
"\000\001\002\003",
= 1,
1,
= 0,
"\000\001\002\003",
= 1,
1,
= 0},
1,
n_faces = 0,
= 0,
0,
= 1,
0x0,
= 0x0,
101723,
next_line = 1,
= 0,
= 0x0,
0x0,
0,
0x5555559a1e80,
Lab",
coor_version = {
{byte_order = 0,
"\000\001\002\003",
= 1,
1,
dig_fp = {
0x0,
0x0,
0x0,
0x0,
0},
0,
0x0,
SF_GEOMETRY,
0x0,
SF_GEOMETRY,
0}},
0}
-136416591,
32767,
140737353923672,
685899776,
"\001\000\000",
-4163,
32767,
off_t_size = 1,
"\020\325\377\377",
32767,
1,
32767,
-10896,
-4163,
310,
-4163,
-136417169,
-136417169,
140737351874544,
140733193388033,
140737488344672,
140736985276032,
302,
0x7fffffffd7b4,
0x7fffe203c70d,
0x83a>,
-136431277,
310,
310},
-201740488,
140737340084280,
140737354101808,
2822930839,
= 120,
4160538376,
<__restore_rt>,
0x7ffff7fcbc58}},
head = {
address 0x13352e3>,
0},
"\377\177\000",
0,
last_offset = 21,
0x0,
0x1>,
0xffffffff,
1952531488,
-9320,
0x17>,
0x0,
1040,
1088,
array_alloc = 64},
= 110}},
119}
Centers = 0x0
acentres = 0
ncentres = 0
apnts1 = 0
    apnts2 = 0
    pnts1 = 0x0
    pnts2 = 0x0
(gdb) l
141 in tavl.c
On Wed, Nov 16, 2016 at 7:14 PM, Eduardo Corbelle Rico <eduardo.corbelle@gmx.net> wrote:
Dear all,
fault”
error. I
bit)
but
bit).
eo.o
rg/g
rass
GRASS 7)
the
same error appears:
Building graph…
Registering arcs…
Segmentation fault
tested
Valgrind
also
Can
you
Markus M
Thank you Markus,
my
should
do otherwise.
comes
compiler
information:
make distclean
make
Markus M
Dear Markus,
along
the way?
Markus M
You do not need these packages when you compile from source.
debugging commands:
.html>
copying”
Reading symbols from /usr/lib/grass70/bin/v.net.iso…Reading symbols
id/5a/060fc6c3da41153d82601e3fa37ba6d88e9c6c.debug…done.
done.
This seems to be the GRASS version installed with your package manager because make install installs by default to /usr/local/:
Building graph…
Registering arcs…
7b0)
at tavl.c:146
(gdb) bt full
599f7b0)
at tavl.c:146
y = 0x0
z = 0x55555599b6c0
p = 0x0
At this stage (tavl.c:146), p should be equal to z, and p has been accessed previously, i.e. the segmentation fault should occur earlier. Therefore I suspect changes in tavl.c introduced when creating the package. You would need to remove all GRASS 7 packages from your system, then compile from source again.
Markus M
O Xov, 17-11-2016 ás 08:52 +0100, Markus Metz escribiu:
<eduardo.corb
> > > > > > > Dear all,
> > fault"
> > > > > > > error. I
(32
> > > > > > > bit)
> > > > > > > but
> > bit).
.osg
> > eo.o
> > > > > > > rg/g
> > > > > > > rass
for
> > > > > > > GRASS 7)
> > > > > > > the
> > > > > > > same error appears:
> > > > > > > > Building graph...
> > > > > > > > Registering arcs...
> > > > > > > > Segmentation fault
libraries. I
> > > > > > tested
> > Valgrind
> > > > > > also
fault.
> > Can
> > > > > > you
> > > > > > Markus M
> > > > > Thank you Markus,
describe
> > my
if I
> > > > > should
> > > > > do otherwise.
> > comes
why it
> > compiler
> > > > information:
> > > > make distclean
> > > > make
> > > > Markus M
> > > Dear Markus,
something
> > along
> > > the way?
> > Markus M
grass-
> debugging commands:
/gpl
> .html>
> copying"
symbols
> done.
100000
> Building graph...
> Registering arcs...
599f
> 7b0)
> at tavl.c:146
> (gdb) bt full
5555
> 599f7b0)
> at tavl.c:146
> y = 0x0
> z = 0x55555599b6c0
> p = 0x0
Markus M
Ok. It seems that I was still running the version installed with the
package manager. When using the version compiled from source, the
segmentation error does not appear at all.
Thank you very much.
Eduardo
On Fri, Nov 18, 2016 at 4:48 PM, Eduardo Corbelle Rico <eduardo.corbelle@gmx.net> wrote:
<eduardo.corb
Dear all,
fault”
error. I
(32
bit)
but
bit).
.osg
eo.o
rg/g
rass
for
GRASS 7)
the
same error appears:
Building graph…
Registering arcs…
Segmentation fault
libraries. I
tested
Valgrind
also
fault.
Can
you
Markus M
Thank you Markus,
describe
my
if I
should
do otherwise.
comes
why it
compiler
information:
make distclean
make
Markus M
Dear Markus,
something
along
the way?
Markus M
grass-
debugging commands:
/gpl
.html>
copying”
symbols
done.
100000
Building graph…
Registering arcs…
599f
7b0)
at tavl.c:146
(gdb) bt full
5555
599f7b0)
at tavl.c:146
y = 0x0
z = 0x55555599b6c0
p = 0x0
Markus M
Can you please report to the responsible Debian package manager that the GRASS 7.0.5 package produces a segmentation fault while the original source code works fine? You would do a big favour to other GRASS users on Debian.
Markus M
O Ven, 18-11-2016 ás 22:45 +0100, Markus Metz escribiu:
<eduardo.corbe
> > <eduardo.corb
Rico
> > > > > > > > > Dear all,
"segmentation
> > > > fault"
> > > > > > > > > error. I
6.4
> > (32
> > > > > > > > > bit)
> > > > > > > > > but
(64
> > > > bit).
rass
> > .osg
> > > > eo.o
> > > > > > > > > rg/g
> > > > > > > > > rass
dataset
> > for
> > > > > > > > > GRASS 7)
> > > > > > > > > the
> > > > > > > > > same error appears:
> > > > > > > > > > Building graph...
> > > > > > > > > > Registering arcs...
> > > > > > > > > > Segmentation fault
> > libraries. I
> > > > > > > > tested
fault.
> > > > Valgrind
> > > > > > > > also
segmentation
> > fault.
> > > > Can
> > > > > > > > you
> > > > > > > > Markus M
> > > > > > > Thank you Markus,
> > describe
> > > > my
know
> > if I
> > > > > > > should
> > > > > > > do otherwise.
that
> > > > comes
see
> > why it
the
> > > > compiler
more
> > > > > > information:
> > > > > > make distclean
> > > > > > make
> > > > > > Markus M
> > > > > Dear Markus,
the
> > something
> > > > along
> > > > > the way?
be
> > > > Markus M
and
> > grass-
> > > debugging commands:
nses
> > /gpl
> > > .html>
it.
"show
> > > copying"
at:
> > symbols
> > > done.
center_cats=1-
> > 100000
input=myroads_net
> > > Building graph...
> > > Registering arcs...
5555
> > 599f
> > > 7b0)
> > > at tavl.c:146
> > > (gdb) bt full
=0x5
> > 5555
> > > 599f7b0)
> > > at tavl.c:146
> > > y = 0x0
> > > z = 0x55555599b6c0
> > > p = 0x0
been
packages
> > Markus M
the
Markus M
Done. Thank you for your time.
Greetings,
Eduardo
