Hi Moritz, Stefan (and Marcus if you’re around?)
Every day is a new day.
Not IOPs, Not memory, Not CPU… Hmm, how about reboot…
As you have suspected, I get no benefit from additional CPUs.
Are you sure the problem is CPU-bound ?
I started by testing v.net (the maintenance module) in parallel - and observed pretty much linear scaling in performance over and above 2 parallel jobs.
So I then proceeded to test v.net.distance… and sure enough, it is now scaling. Really different looking CPU performance profiles to yesterday, when it wasn’t scaling. On top, all the v.net CPUs are humming at 50%, the other 50% used by pg processes.
Below are some iostat profiles of the different parallel test.
So v.net.distance does parallelise nicely. The neatest way is to launch GNU parallel from within a single grass_batch_job. I will write up on the grass wiki in the coming 2 weeks.
Mark
---------------V.NET ---------------
Single job
v.net
iostat 1
TOTAL SCRIPT TIME: 284
avg-cpu: %user %nice %system %iowait %steal %idle
15.92 0.00 35.32 0.50 0.00 48.26
Device: tps Blk_read/s Blk_wrtn/s Blk_read Blk_wrtn
xvde 18.00 8.00 744.00 8 744
xvdj 0.00 0.00 0.00 0 0
20.00 0.00 34.00 0.50 0.00 45.50
xvde 9.90 0.00 633.66 0 640
22.50 0.00 35.50 0.50 0.00 41.50
xvde 9.00 0.00 592.00 0 592
Two parallel jobs
v.net
iostat 1
TOTAL SCRIPT TIME: 397
32.16 0.00 67.84 0.00 0.00 0.00
xvde 19.00 0.00 1024.00 0 1024
39.50 0.00 60.50 0.00 0.00 0.00
xvde 19.00 0.00 912.00 0 912
35.50 0.00 64.50 0.00 0.00 0.00
xvde 16.00 0.00 1024.00 0 1024
Four parallel jobs
v.net
iostat 1
TOTAL SCRIPT TIME: 388
32.92 0.00 67.08 0.00 0.00 0.00
xvde 31.00 0.00 1952.00 0 1952
33.83 0.00 66.17 0.00 0.00 0.00
xvde 35.00 0.00 2016.00 0 2016
xvde 61.00 0.00 4032.00 0 4032
---------------V.NET.DISTANCE ---------------
Single job
v.net.distance
iostat 1
TOTAL SCRIPT TIME: 88
4.00 0.00 21.00 0.00 0.00 75.00
xvde 0.00 0.00 0.00 0 0
7.75 0.00 21.75 0.00 0.00 70.50
6.27 0.00 22.56 0.00 0.00 71.18
xvde 4.00 0.00 56.00 0 56
Two parallel jobs
v.net.distance
iostat 1
TOTAL SCRIPT TIME: 96
9.02 0.00 40.85 0.00 0.00 50.13
11.75 0.00 43.75 0.00 0.00 44.50
xvde 3.00 0.00 40.00 0 40
9.50 0.00 40.75 0.00 0.00 49.75
Four parallel jobs
v.net.distance
iostat 1
TOTAL SCRIPT TIME: 124
17.96 0.00 82.04 0.00 0.00 0.00
xvde 3.00 0.00 32.00 0 32
18.50 0.00 81.50 0.00 0.00 0.00
21.50 0.00 78.50 0.00 0.00 0.00
xvdj 7.00 0.00 64.00 0 64
Eight parallel jobs
v.net.distance
iostat 1
TOTAL SCRIPT TIME: 122
19.00 0.00 81.00 0.00 0.00 0.00
19.50 0.00 80.50 0.00 0.00 0.00
18.65 0.00 81.35 0.00 0.00 0.00
xvde 3.00 0.00 48.00 0 48
