i’ve some problem with v.net.path
my problem is: how use v.net.path. it looks as a stupid question, but i’m not able to use in correct way.
if i don’t specify the weight of forward arc and backward arc i receive as output the shortest path, and this works well.
now, if i specify the length of the path as weight i should receive the same path, right? but this doesn’t work.
how v.net.path use default weight? how i can put the right value to find the shortest path?
because i want to assign different weight from an arc in order to have a path that respect the street’s law (one-way can be taken only forward and so on)
the length of the line is taken using v.to.db.
how v.net.path works without parameters of arc’s weight? what weight by default are assigned (and how it is calculated?)?
ideas?
bye
Stefano
