[GRASS-user] v.net tools with polygons
Hi list,
I’m beginning to learn and use the v.net tools in Grass in order to evaluate the distance from several crop fields to a processing plant.
I’ve successfully build the road network with the end nodes but now I’m in doubt. My starting points in the analysis are crop fields, which are polygons. So what is the best (or most common) practice?
  1. Use the field centroids as starting nodes?
  2. Add field polygon boundaries to the network and run v.net.distance backwards (from mill to fields)?
  3. Some other option?
Also, if I’m to add the field boundaries to the network, how would I go about it? Should I first v.patch the field with the roads layer and then run v.net?
Thanks
Daniel
On 02/03/15 21:39, Daniel Victoria wrote:
Hi list,
I'm beginning to learn and use the v.net <http://v.net> tools in Grass
processing plant.
I've successfully build the road network with the end nodes but now I'm
1) Use the field centroids as starting nodes?
2) Add field polygon boundaries to the network and run v.net.distance
3) Some other option?
I don't think that there is a best practice for this. It all depends on your application and the desired outcome. Do you want average time/distance from anywhere in the field to the plant ? Then probably the centroid is ok. Or do you want distance from the point of the field that is closest to the network ? Then you could get the coordinates of that point through v.distance (with upload=to_x,to_y) and use these points as nodes.
Also, if I'm to add the field boundaries to the network, how would I go
run v.net <http://v.net>?
Adding field boundaries still does not answer the question of where to put the start/stop point of your paths...
If you want to add them to the network then yes, patching would be the best option, AFAIK.
Moritz
Thanks
Daniel
grass-user mailing list
grass-user@lists.osgeo.org
Ok Moritz,
Thanks for the tips. I’ll try to go the centroids way
Daniel
On Tue, Mar 3, 2015 at 5:35 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi list,
I’m beginning to learn and use the v.net <http://v.net> tools in Grass
processing plant.
I don’t think that there is a best practice for this. It all depends on your application and the desired outcome. Do you want average time/distance from anywhere in the field to the plant ? Then probably the centroid is ok. Or do you want distance from the point of the field that is closest to the network ? Then you could get the coordinates of that point through v.distance (with upload=to_x,to_y) and use these points as nodes.
Adding field boundaries still does not answer the question of where to put the start/stop point of your paths…
Moritz
Thanks
Daniel
