I'm trying to export a 3d vector to an ascii file that just contains x y z using v.out.ascii, but the output also puts in the numeric vector id which is causing havoc with other importers. Is there any way to disable this?
--j
Jonathan A. Greenberg, PhD
Postdoctoral Scholar
Center for Spatial Technologies and Remote Sensing (CSTARS)
University of California, Davis
One Shields Avenue
The Barn, Room 250N
Davis, CA 95616
Cell: 415-794-5043
AIM: jgrn307, MSN: jgrn307@hotmail.com, Gchat: jgrn307
Not exactly what your asking, but you could pipe the output through awk to remove any fields that you don't want.
Mike
--j
One Shields Avenue
The Barn, Room 250N
Davis, CA 95616
Cell: 415-794-5043
2008/1/18, Jonathan Greenberg <greenberg@ucdavis.edu>:
disable this?
not sure if I understand your question,
$ v.out.ascii x
1619923.0297213|4836235.79480289|0.01571819|1
1619927.57223432|4836235.09835698|8.05628783|2
1619910.45256599|4836241.22590928|6.82026114|3
To eliminate category number from output (4th column), you can use e.g. awk
