[GRASS-user] v.out.ogr not working
Group,
I have been spending a lot of time on this and I need help. I am using grass72/ gdal2.2 and both my python script and grass72 are not producing the expected output when i run v.out.ogr! v.in.ogr does work though!
v.out.ogr input=parcel type=area output=/home/atourej/Data/prcl.shp
parcel has 1107 areas and program run in 0 second with no output!!
Your insight is appreciated
alassane
Hi Alassane,
maybe the problem can be the name size of columns in the attribute table.
Try with short name.
Best.
2018-01-09 22:56 GMT-02:00 alassane toure <atourej@gmail.com>:
Group,
alassane
grass-user mailing list
grass-user@lists.osgeo.org
Maurício Humberto Vancine
Ecologist - Master Candidate in Zoology
São Paulo State University (UNESP), Rio Claro, SP, Brazil
Site | Lattes | ResearchGate | GitHub | ORCID | Google citations | Impactstory
GRASS GIS uses its internal vector format, so v.out.ogr just expects a map name.
If you want to write out SHP or other formats directly, check
https://grass.osgeo.org/grass72/manuals/v.external.out.html
HTH,
Am 10.01.2018 1:56 vorm. schrieb “alassane toure” <atourej@gmail.com>:
Group,
Group,
No, v.out.ogr expects an OGR datasource and optionally an OGR layer.
Try
v.out.ogr input=parcel type=area output=/home/atourej/Data output_layer=prcl
If this is also not working, please post the messages/warnings/errors of v.out.ogr.
Markus M
HTH,
Thanks for your response Mauricio.
Ok I will try it but v.out.ogr in GUI and in python script works using GRASS70 though!
alassane
On Tue, Jan 9, 2018 at 10:13 PM, Maurício Vancine <mauricio.vancine@gmail.com> wrote:
Hi Alassane,
Best.
Group,
alassane
Thanks Markus,
I will try your suggestion too!
alassane
alassane
Hi Alassane,
Best.
Group,
alassane
Markus,
Here is the system response. The code goes through the process but does not create the output file!
Inline image 1
On Wed, Jan 10, 2018 at 9:28 AM, alassane toure <atourej@gmail.com> wrote:
Thanks Markus,
alassane
alassane
Hi Alassane,
Best.
Group,
alassane
On Wed, Jan 10, 2018 at 5:38 PM, alassane toure <atourej@gmail.com> wrote:
Markus,
The first two errors make sense, you would need to use the --overwrite flag. The last call of v.out.ogr is strange because there are no output messages at all, even though there should be some. Can you try with GRASS 7.5?
Markus M
Thanks Markus,
alassane
alassane
Hi Alassane,
Best.
Group,
alassane
Ok GRASS75 it will be. Will keep you posted!
Again thanks guys for making time for this
On Wed, Jan 10, 2018 at 5:14 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Markus,
Markus M
Thanks Markus,
alassane
alassane
Hi Alassane,
Best.
Group,
alassane
here is the error message from running the script (Grass72). I will install Grass75 today as i have no clue where to locate the error file and troubleshoot.
Inline image 1
Markus,
Markus M
Thanks Markus,
alassane
alassane
Hi Alassane,
Best.
Group,
alassane
Markus & Mauricio,
v.out.ogr now works under grass74. ESRI Shapefile is not a default and its specification is required.
v.out.ogr input=grassvector type=area format=ESRI_Shapefile output=dir/output.shp
Thanks for your help!!!
alassane
(attachments)
Inline image 1
Markus,
Markus M
Thanks Markus,
alassane
alassane
Hi Alassane,
Best.
Group,
alassane
On Thu, Jan 11, 2018 at 6:08 PM, alassane toure <atourej@gmail.com> wrote:
Markus & Mauricio,
Excellent!
Yes, because we switched to GeoPackage vector as the default export
vector format in GRASS GIS 7.4:
https://trac.osgeo.org/grass/wiki/Release/7.4.0-News#Majormodulechanges
--> v.out.ogr: ...
Glad that it now works,
markusN
Markus & Mauricio,
Excellent!
It is a pity that the GUI does not report the actual error.
GeoPackage is the recommended vector output format, please use it!
Markus M
→ v.out.ogr: …
markusN
