[GRASS-user] v.out.ogr to KML ERROR 1: Latitude is invalide
This is a vector layer transfered from a raster and its general info can be seen as follows:
| Layer: swi_0@PERMANENT
| Mapset: PERMANENT
| Database: D:/GrassDataBase
| Title:
| Map scale: 1:1
| Map format: native
| Name of creator: Administrator
| Organization:
Source date: Thu Jun 18 20:51:48 2009
Type of Map: vector (level: 2)
Number of points: 0 Number of areas: 88
Number of lines: 0 Number of islands: 79
Number of boundaries: 229 Number of faces: 0
Number of centroids: 84 Number of kernels: 0
Map is 3D: 0
Number of dblinks: 1
Projection: Universe Transverse Mercator (zone 0)
N: 2762370.84493965 S: 2668889.78644383
E: 636604.74247833 W: 592287.35339113
Digitization threshold: 0
Comments:
then I want to export it to kml and add it to the google earth, I use the commond:
g.region vect=swi_blue@PERMANENT
v.out.ogr input=swi_blue@PERMANENT type=area dsn=d:/blueNew.kml layer=1 format=KML
and I got the errors:
arning 1: Layer name ‘swi_blue@PERMANENT’ adjusted to ‘swi_blue_PERMANENT’ for XML validity.
Exporting 4893 areas (may take some time) …
ERROR 1: Latitude 2764980.037140 is invalid. Valid range is [-90,90]. This warning will not be issued any more
Warning 1: Longitude 638073.992861 has been modified to fit into range [-180,180]. This warning will not be issued any more
9259 features written
4476 features without category written
it seems that there is something wrong with the Coordinate,but Latitude 2764980.037140 is the same with the general info from the command v.info map=‘’‘’‘’.
I wonder it is my problem or the grass?
        | Projection: Universe Transverse Mercator (zone 0)
        | N: 2762370.84493965 S: 2668889.78644383
         | E: 636604.74247833 W: 592287.35339113
        | Digitization threshold: 0
        | Comments:
g.region vect=swi_blue@PERMANENT v.out.ogr input=swi_blue@PERMANENT type=area dsn=d:/blueNew.kml layer=1 format=KML
arning 1: Layer name 'swi_blue@PERMANENT' adjusted to 'swi_blue_PERMANENT' for XML validity.
Exporting 4893 areas (may take some time) ...
If I'm not mistaken, kml files need to be in Lat/Lon. WGS84 datum, *not* UTM
       | Mapset: PERMANENT
      | Database: D:/GrassDataBase
      | Title:
       | Map scale: 1:1
       | Map format: native
      | Name of creator: Administrator
       | Organization:
      | Source date: Thu Jun 18 20:51:48 2009
      | Number of points: 0 Number of areas: 88
       | Number of lines: 0 Number of islands: 79
       | Number of boundaries: 229 Number of faces: 0
      | Number of centroids: 84 Number of kernels: 0
      | Map is 3D: 0
      | Number of dblinks: 1
      | Comments:
it seems that there is something wrong with the Coordinate,but Latitude 2764980.037140 is the same with the general info from the command v.info <http://v.info> map=''''''.
On the KML page of OGR it says: "Note that KML by specification uses only a single projection, EPSG:4326" [1]
It also says "As such OGR will create layers in the correct coordinate system and transform any geometries."
Not sure how to interpret this, but from your error message, I would guess that you have to reproject your vector to a epsg:4326 location first, before exporting with v.out.ogr.
Moritz
[1]http://www.gdal.org/ogr/drv_kml.html
| Layer: swi_0@PERMANENT | Mapset: PERMANENT | Location: newlocation | Database: D:/GrassDataBase | Title: | Map scale: 1:1 | Map format: native | Name of creator: Administrator | Organization: | Source date: Thu Jun 18 20:51:48 2009 |----------------------------------------------------------------------------
| Type of Map: vector (level: 2) | | Number of points: 0 Number of areas: 88 | Number of lines: 0 Number of islands: 79 | Number of boundaries: 229 Number of faces: 0 | Number of centroids: 84 Number of kernels: 0 | | Map is 3D: 0 | Number of dblinks: 1 | | Projection: Universe Transverse Mercator (zone 0) | N: 2762370.84493965 S: 2668889.78644383 | E: 636604.74247833 W: 592287.35339113 | | Digitization threshold: 0 | Comments:
Moritz
Sorry, just reread your message, and my answer is probably not really helpful. In fact v.out.ogr does transform your data to EPSG 4326, as the following message shows:
No, idea what the ERROR means. What does the resulting KML file look like ?
You still might want to try to reproject (v.proj) to EPSG 4326, just to see what happens.
Moritz
